6 members (Bill Hanlon, fonz8261, Shaffer's1950, tclederman, Hotrod Lincoln, Charles in CA), 70 guests, and 3 robots.
Topics128,087
Posts1,056,376
Members48,442
#1026411 05/05/2014 7:37 PM
I'm stumped! headscratch I have the rear brake calipers rom an '02 Camaro bolted to my '74? 10 bolt rear. The pedal has always been somewhat soft, but this past weekend I noticed what appeared to be brake fluid buildup all along the inside of the passenger side wheel. I looked over the caliper & hose but find no obvious signs of leakage. Any Ideas??
Robert C.
I'm a Genius in the making.
1950 3600
Your banjo fitting might be leaking under pressure? Are you sure it's brake fluid? I've never seen brake fluid "build up". Could you have a leaking axle seal on that side?
My 46 GMC on Photobucket
Might want to check the level of the rear end.
If it is brake fluid, it will wash off with water. If it is axle lube, it will not wash off with anything. I can still smell it under my fingernails and I haven't worked on my rear axle in two years.
Carl
Dang it! It's the seal, didn't even think about that! I'd rather work on the brakes than pull the rear end apart!
Robert C.
1950 3600
Carl
I think you should wash your hands more often Carl wink
Carl
Next thing you are probably going to suggest is for me to make my bed in the morning even though I'll just mess it up tonight. smile
Got 'er done!
Robert C.
1950 3600
Carl
Nah that's your wife's job wink
Originally Posted by mobileortho
Got 'er done!
Great! Brakes work much better when they're not covered in gear lube!
