3 members (TexasA&M48Truck, TUTS 59, Stovebolt48), 62 guests, and 8 robots.
Topics128,021
Posts1,055,348
Members48,420
#102662 09/20/2007 4:17 PM
what is the points setting on a 1954 chevy stakebed model 3600.
#102663 09/20/2007 10:37 PM
mrhaney,
The 1954 Shop Manual states 0.018" (0.015" to 0.022") for used points and 0.022" (0.018" to 0.024") for new points.
I usually set them 0.019" new and 0.016" used and check them every 1,000 miles.
Someone else might have dwell settings (30-32 degrees??). I use a dwell meter, if one is available.
Tim
#102664 09/21/2007 4:16 PM
thank you very much. i was setting them at .016 and it would run but not as good as i am use to. does .003 make a lot of difference? what affect happens when you go up or down from the correct setting
#102665 09/21/2007 4:56 PM
I always set mine at .019. If i guage it too tight, I am still within spec.
dwell effects timing
timing does not effect dwell
#102666 09/21/2007 8:28 PM
Riding in the Passing Lane
When the gap changes it changes the timing. Get the gap correct & put a tiny pinch of grease on the cam. Then set the timing.
1972 Chevy c10 Cheyenne Super
#102667 09/21/2007 8:35 PM
mrhaney,
When the points are closed, your coil is "charging" (saturating), which will allow a full, hot spark to the plugs when the points open. If the points are set too tight (I think), this saturation time is diminished which can result in a poor spark, hence poor performance.
Stuart
#102668 09/21/2007 10:26 PM
Apprentice
Apprentice
backwards
Later JJ and 4
Keep the shiney side up
#102669 09/21/2007 10:28 PM
Apprentice
Apprentice
( I think )
Later JJ and 4
#102670 09/22/2007 1:02 AM
Small point gap = shorter saturation time = larger dwell reading.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
#102671 09/22/2007 6:04 PM
Small point gap = longer saturation time = larger dwell reading.
#102672 09/22/2007 6:58 PM
I'll cast my vote with the telephone tech from WA. smile
Stuart
#102673 09/22/2007 11:12 PM
Apprentice
Apprentice
Waldo, you da man.
My 1947 Studebaker Shop Manual agrees with Waldo.
Also my 1968 Motors, Truck repair Manual, 21st
edition, page 22 says "small gap = excessive dwell".
I have lots of old books, maybe I should get some new ones and try to catch up with technology or am I too far behind?
JJ and 4
Later JJ and 4
#102674 09/29/2007 9:45 PM
You are right again Waldo53,longer saturation time.
Please Note:
50 percent of the time,I am right every time!
Wanted Good Woman:
