7 members (TexasFarmTruck, Otto Skorzeny, MOTOXFAMILY, Phak1, kurbside bolter, 2 invisible), 157 guests, and 3 robots.
Topics128,268
Posts1,058,378
Members48,485
#1026044 05/04/2014 2:58 AM
I pulled my non original 230 out of my 63 c-10 and put in a 1963 283.I bought a 283 V-8 radiator and fabricated some lower brackets and installed the radiator in the stock location where the v-8 radiator would have been located from the factory .Now that the radiator is sitting higher ,the fan is not centered in the radiator and is more towards the bottom of the radiator that the top.This seems like it would not cool as well and be hard to get a shroud to fit .The six cylinder radiator is 18 inches wide and the new radiator I have is 25 inches wide.I have 24 inches of room between my frame rails ,so I was wondering if I could get a 3 core radiator that is 22 inches wide and drop it in the lower 6 cylinder location between the frame rails and just install wider lower radiator brackets .That would center up my fan and bring my fan closer to the radiator.But my question is would it cool.I do live in Texas but I am not running and AC unit the motor is a mild build .Any advice you can give me would be great.
Thank You
Do you have a shroud? If not I'd suggest you stick with what you have and get one thumbs_up
[IMG]http://i1003.photobucket.com/albums/af160/jbowencowboy/DSCN0002.jpg[/IMG]
Hopfully these pics came out.I dont think I can add a shroud because of the fan location to the radiator .
Longhorn
Originally Posted by Longhorn
I don't think I can add a shroud because of the fan location to the radiator.
Longhorn
Maybe a "stock" shroud won't work. You may need to make a custom shroud.
http://www.thebrassworks.net/fans-and-shrouds.html
http://www.route66hotrodhigh.com/FanShroud.html
http://www.forabodiesonly.com/mopar/showthread.php?t=198911
Yes I thought about fabricating one up but even with the 4 inch fan spacer that I have ,I would have to have a shroud at least 8 inches long ,and I dont think that would look very good.I was thinking if I could reduce my radiator size by 2 to 3 inches in width I could drop it down 3 inches and move it closer to the fan 2.5 inches {Where the 6 cylinder radiator went } and then fab a shroud that is 5.5 inches.Running a 3 core 22x19 radiator is a heck of a lot bigger that the stock 6 cylinder radiator but my question is would it be big enough to cool the 283.Also I want to thank you for the links you sent fantastic info.
Thanks Longhorn
Awesome article related to Bulletproof Cooling System
