Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 84 guests, and 3 robots.
Topics128,290
Posts1,058,566
Members48,492
A friend asked me to help him get a fairly decent '54 4400 up and going; it runs, but has no brakes.
Since he wants to use it in parades and things I suggested an upgrade to at least a dual chamber master on it, as I presume it just has a single now. But I'm not that familiar with these big trucks.
What kind of options do I have to go on here? Are there brake parts suppliers for these trucks?
Nothing wrong with the original setup, I just rebuilt mine. If I stomp on the pedal hard, it will throw you through the windshield when the bed is empty.
Bruce
My Trucks
Stuff I Collect
Yes, but if it's used only occasionally, it would be nice to have another pump or two of tbe pedal before it's downshift and pray. And either way, I need to know where to source parts for this so I can give him some kind of budget to get it done with.
FWIW, a hydroboost setup wouldn't be a big deal to install if need be, we have a '55-56 1-ton that once had a plow on it from which I can source a 6-cyl pump setup; although who knows what shape that is in, as that old tow truck looks like it was ridden hard, put away wet, and then left to sit for 30 years.
