1 members (klhansen),
136
10
Mod | | | Forums66 Topics128,281 Posts1,058,470 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | My son was driving our 53 the other day with me following him. We were giving it a workout trying to see if we have stopped our tranny leak. The sun was shinning brightly, and I couldn't see our blue dot tail lights at all. I think we were waiting to be rear ended. I ordered a set of led tail lights from Safeway. What a difference it makes. Now you can see the brake lights and turn signals on a sunny day. I guess there goes originality for safety. | | | | | Joined: Aug 2005 Posts: 6,379 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,379 | How about posting a link to the lights?
| | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | The blue dot lights suck for daylight use and even at night they reduce the distance from which the lights can be seen, probably why they were illegal. They are still illegal, AFAIK, but I doubt that anyone would get a ticket for using them now. | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | Sorry Tiny, I said Safeway, meant Speedway.
http://www.speedwaymotors.com/p/4051,964_1940-53-Chevy-Truck-LED-Taillights.html | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | I switched to LED for the same reason | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Pardon my ignorance but are these a simple bolt on and wire in or do you need some sort of electronic gizmo to make them work? | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | Just bolt and slice,Bill.If you leave the front signals lights 1157,you won't have to change the flasher | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | I did the same ... for my '54: See Here - with link to buy.
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | Mine was only a bulb swap-out. No bolt and splice for me. I love'em. You have to look very closely to see that they aren't stock. If you are looking closely, then they are doing their job!
Bill | | | | | Joined: Nov 2000 Posts: 700 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 700 | Are the LEDs mounted integrally with the lens cover? If not, and this may be a totally ignorant question, would the glass lenses with the "Blue Dots" fit in the bezel?
TxLaTx - Can you link the bulb you used?
Don My 1941 in the Stovebolt Gallery My Photo AlbumBut I tried, didn't I? ... At least I did that. RP McMurphy The past belongs to the future...but only the present can preserve it. Besides the noble art of getting things done, there is a nobler art of leaving things undone. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | There's several types of LED conversions out there, one that has the LEDS as part of the lens, one that's an LED panel that mounts inside the housing behind the existing lens, and then there's the one that's a simple bulb replacement, which is very popular with the "Tuner" crowd. The lens and bulb types can not be used with Blue Dots at all. In the case of the lens type, the LEDS are part of the lens itself and cuting into it to install a Blue Dot will ruin them, plus the dot will not work anyways. On the bulb replacement type, the dot will end up sitting right over the top od the bulb. In the case of LEDs, the lens color has to be either clear or match the color of the LED illumination. So a blue dot will actually block the light from an led making the lamp dimmer. The panel type (I used on from Technostalgia) can be modified, there's enough room under the panel when installed to add a blue LED in the position of the dot on the lense. That's how I did mine. The dot makes no difference in the brightness of the light. http://rides.webshots.com/photo/2368955000092261295qrmCdN http://rides.webshots.com/photo/2739260370092261295Qaohye http://rides.webshots.com/photo/2752257200092261295eZVJHY
Bill Burmeister | | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | Don- Here is a link to a site that has bulbs that look identical to the pair I bought locally at AutoZone. After learning that you buy bulbs the same color as the lens, I got 1157R (red) dual intensity 19 LED "bulbs." A red lense will not filter out red light put out by the LED. But I think in the case of blue dots, the small blue lense WILL filter out some of the light emitted by the red LED, making it appear dimmer than non-blue dotted. The site I linked to has them for about $7/ea + freight. At AutoZone, I bought the pair for around $16. Bill | | | | | Joined: Jul 2006 Posts: 327 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 327 | I want to switch to leds as well. I need to make sure I know what to get here before I order. My system is 6 volts and I have turn signals front and back. I went to thier website TX recommended.. Do I Change the front parking lights aswell or leave them??? Do i get the wide angle or the narrow angle bulbs I think the 1156 are the ones I need
I see they have an Electronic flasher or do I need a load resister for both front and back or will the flasher unit be the way to go... Remember I'm a 6 volter
I need to be sure here I live here in Canada and its a hassle to return all this stuff. Thanks Peter | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Peter,
Thanks for asking about the 6v LEDs. No mention of system voltage, above.
I think there are 6v LEDs for our tail lamps, but it would be nice to hear from someone who is actually using them (tail lamps, parking lamps, head lamps).
Tim | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 |
Bill Burmeister | | | | | Joined: Jul 2006 Posts: 327 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 327 | Sorry let me clarify this I should of said 6 volt 1154 bulbs not 1156... Or will the 12 volt bulbs work but not as bright... but brighter then regular lights confused yet... Peter... | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | 12 volt bulbs will be much dimmer than any 6 volt bulb at six volts. You won't be able to see them, but they will last forever! | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Has anyone had first-hand experience with 6v LEDs in tail lamps? | | | | | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | Off subject on the LED's but I bought halogen dual filament bulbs from JCW. Not too hot and twice as bright as the regular bulb. Looks original. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I tried the halogens, got the from Auto Zone. While they were very bright, I found the life to be somewhat short. I only got about 6 months out of them. The ones I have in the backups are doing much better, though.
