0 members (),
364
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 321 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 321 | So I got my 1952 Chevy 1 ton delivered on Monday night from Indiana to my upstate NY hometown of Mechanicville...and I am starting to look it over...searching for some lower gears ratio for more drive-ability but I also noticed my truck has no rear shocks...is that normal???...If not what are you 1 ton guys using for rear shocks??? I noticed I had a factory installed brake booster....do you 1 ton guys leave this in place and if you do how does it work?? Oh yeah this is set up for a dump box, is that a good thing or no?? Any insight would be great. MikeC
1951 Chevy 3800 1-TonHoward KnappIn the Stovebolt Gallery1948 Chevy 1-Ton (sold Nov 2017)1953 Chevy 1-Ton (sold 10/1/2016) | | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | The 1 tons came standard without shocks. Some guys add them, there is a thread earlier about adding shocks. I have a 1951 1 ton with dual rear wheels and a grain box and it has a brake booster on it, have not gotten far enough to decide anything on it yet, Immediate goal here is to get that truck cleaned up and running. Jerry
| | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Are you sure it's a 1 ton? The Hydra-Vac units came on the bigger trucks.
Bruce | | | | | Joined: Dec 2006 Posts: 321 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 321 | I am pretty sure it is a 1 ton, I did a search thru the VIN number and it was built in Kansas City and it is appears to be a 1 ton. The VIN tag is 5KSL 3194....Single wheel rear too. It has a lift mechanism on the back also.
MikeC
1951 Chevy 3800 1-TonHoward KnappIn the Stovebolt Gallery1948 Chevy 1-Ton (sold Nov 2017)1953 Chevy 1-Ton (sold 10/1/2016) | | | | | Joined: Dec 2012 Posts: 72 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 72 | My '54 1 ton GMC has Hydrovac on it. Looks factory to me. I love the way it helps to stop this truck, it's a nice feature, I wish my '49 1 ton had it. Neither one of my 1 tons have rear shocks. https://www.flickr.com/photos/ajporsche/sets/72157640409893304/ | | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | My '57 3800 has hydrovac and I'm 99% certain it came that way from the factory. It could have been special order because it was a government truck. http://s305.photobucket.com/user/jfnar/media/57%20chevy%203800/7f5847c2.jpg.html
'64 swb stepside (gone) '57 1 ton '53 phone truck '59 swb '46 1 1/2 ton '68 swb gmc
| | | | | Joined: Feb 2014 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2014 Posts: 46 | im inclined to up-grade brakes on my 52 1 ton/3800. ive been on free rides to many times(run out of brakes before ya run out of hill).70 torino:turned turtle.international 1 1/2 ton:ride that made me feel old,after i shoock like a leaf for a bit.had 450 case on the back, backward down a hill and around a corner.i already have compleat 14 bolt rear.ive found master cylunders for 47-54 gm trucks that mount under cab,some with vacuume booster(dual diaphram),and bracket for under $200.one with adjustable goodie to work so brakes are better empty and loaded,all for under $200.best of luck to you all. and good luck on your projects | | | | | Joined: Dec 2013 Posts: 45 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 45 | Hi Mike4193, Yes your 52 is a 1ton. Go to stovebolt vin buster and put in your vin. and it will tell you what size, where and when you're truck was built. Gerry Lee | | |
