4 members (WICruiser, Gray_Ghost, Bill Hanlon, Nick in Manitou), 125 guests, and 2 robots.
Topics128,109
Posts1,056,269
Members48,439
Hi All
Is there a way to replace just the socket fitting from the top of the upper shock mounts? Can you get replacement fittings and press or weld them in?
The mounts themselves are solid and it seems like a shame to replace the whole thing.
52 3100 project
54 3100 / 3112 ice cream truck, next project
I've seen universal shock mount bushings kits at the auto parts store
They come with rubber bushings and 2 cup washers.
Wurlitzer:
Is the hole in the mount worn larger than normal due to failed bushings. If so, I suppose you could weld the hole closed and then drill the proper hole size for the shock shaft. But, in the end all this would be easiest if you remove the entire mount to either replace or weld.
Good luck.
I think Classic Truck Parts (Chevy Duty) has the upper shock brackets available. You'd have to grind the rivets off and remove the old bracket and bolt or rivet a new one on....
I think that wurlizter46 is interested in just replacing the "cup/socket/fitting" that the shock's top-post goes through in upper mounting plate.
Yes, is there some way to replace just that pressed-on cup/socket/fitting thing?
Some of mine are missing or loose. The brackets are otherwise solid, with a clean hole where the cup thingee should be.
It seems that a replacement would have to be welded or pressed on, or threaded together from both sides of the hole, since the shock pushes and pulls in both directions?
52 3100 project
