4 members (tclederman, FAST55, JW51, 1 invisible),
88
Mod | | | Forums66 Topics128,269 Posts1,058,398 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2012 Posts: 201 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 201 | When I started driving my '46 2-ton, the brakes worked great. It has had a brake job at some point in its recent history. The problem I'm having is that if the truck sits for a while, the pedal will go to the floor on the first pump. After that, it works fine. Plenty of resistance and I can lock the wheels on gravel at low speed. I have looked all over for leaks and found none. My mechanic couldn't see any leakage either. Once pumped up, it stops great and the pedal holds just like I would expect. Now the question; what could cause this? The mechanic suggested adjusting the brakes, which I did, but it still happens on the first pump of the day. After that, it's fine. Could it be the master cylinder? The Hydrovac? Or is it just the system design? Thanks for any information you can give. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Master cylinder is probably the culprit | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Agree, the master cylinder. A very small leak caused by wear. The first pump clears the air bubble. | | |
