7 members (TexasJim50, rick46ia, cmayna, Southerntruck, SNOYL, ShopRag, Mike Roache),
45
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,006 Posts1,055,271 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 127 Shop Shark | | Shop Shark Joined: Mar 2008 Posts: 127 | Has anybody out there ever made a wire harness for a 57 Chevy 2 Ton on a bench? And if so, what are the lengths of each wire? I have a schematic for my truck and want to make a harness.
Glory Bound...
| | | | | Joined: Nov 2010 Posts: 430 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 430 | Wow... Thats a specific question. I don't think anyone would be able to answer that one. I have made plenty of wiring harness including the one in my 46 2-ton. Never have I made one on the bench. It's possible, but you will be spending 10 times longer to do the work than you need to...
| | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | I.M.O.,by the time you buy all of the color-correct wire and terminals,etc.etc.etc.,you'll have more time and money invested than if you bought a higher dollar unit. I'm installing an "American Autowire" with 18-circuit fuse panel. I may never use half of the acc'y terminals,but I plan on installing a 12,000 Lb. winch.so I wanted to up-grade for a fuse block,(one-wire 60-amp alternator,H.E.I. dizzy),as opposed to a circuit breaker, incorporated into the origional system. | | |
