| | | Forums66 Topics128,131 Posts1,056,723 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#10249 12/03/2004 5:21 AM | Joined: Nov 2004 Posts: 7 Junior Member | | Junior Member Joined: Nov 2004 Posts: 7 | I could really use an axle seal and gasket set for the front differential on my NAPCO truck. I saw one last year on ebay but didn't/couldn't buy it at the time. Does anyone have a source I could try??? She's leaking pretty good, appreciate your help. | | |
#10250 12/03/2004 3:49 PM | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | Try the Jim Carter catalog, they have a NAPCO section. Also, I think this is the site that actually sells the NAPCO rebuild kits offered periodically on eBay: http://doonan.home.mindspring.com/ddautoparts.html. I have bought a number of rebuild kits from them, they seem to be very nice. Just make sure you get the right year & sizing (1/2, 3/4 ton, etc.) | | |
#10251 12/04/2004 1:27 AM | Joined: Aug 2003 Posts: 17 New Guy | | New Guy Joined: Aug 2003 Posts: 17 | Which seals are you loking for? The axle shaft seal is CR14864. The wiper seals are availble from Jim Carter and Vintage Powerwagons. I had to make a few of mine. A good bearing shop should have most of them. Where are you located?
58 1 ton Napco 59 1/2 ton Napco 58 1/2 ton Napco 55 1 ton 9’ bed 58 3/4 ton stepside 55 LCF boom truck (3) 57 2 tons
#10252 12/09/2004 12:08 AM | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | Try N.A.P.A auto parts.You'll be suprised what they have or can get you
dan-pa
#10253 12/09/2004 10:10 PM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Try CarQuest, too. Anyone who carries wheel cylinders for a '39 American LaFrance fire truck can find ANYTHING. | | |
