2 members (John Dlugos, 1 invisible), 150 guests, and 3 robots.
Topics128,110
Posts1,056,241
Members48,437
#1024877 04/28/2014 9:38 PM
This gauge needle with an empty tank is way below the 'E' after maybe 4 gallons she's at the 'E'. So is the gauge shot or just bad connection from sender?
Anyone
1946 1/2-Ton Chevy
not an electrical problem, mechanical, just need to bend the needle up where it belongs
Bend the needle or the float???
1946 1/2-Ton Chevy
the needle, the gauge should only read below E when power is off, the float can't move the gauge beyond it's range, sender just shows zero to 30 ohms, the gauge is "misinterpreting" that .... OTOH, it doesn't hurt to know when it reads E that you still have enough gas to get to a station, so what it reads when the tank is full might be a better point to check
Thanks Bill, I'll check that out as well.
1946 1/2-Ton Chevy
