3 members (Gdads51, gswbbc, Hotrod Lincoln), 142 guests, and 2 robots.
Topics128,047
Posts1,055,532
Members48,424
#980305 10/22/2013 3:08 AM
Are running boards from a 1-1/2 ton the same as 3/4 ton factory flatbed? (short) Want to bolt 1-1/2 ton running boards to 3/4 ton fenders. (else I'll have to buy different running boards).
These are for a 1946 Chevy 3/4 ton.
Grease magnet
41flatbed #980812 10/23/2013 9:55 PM
I think you'll find the 1.5 ton chassis use a shorter running board that only extends to the rear of the cab. That leaves the spece between the back of the cab and the front of the rear fenders open.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
41flatbed #980823 10/23/2013 10:34 PM
I've never seen rear fenders on a flatbed. I would expect the 1 1/2-2 ton boards to work on a 3/4 ton flat bed. But I have no idea how 3/4 ton factory flatbed boards were mounted.
41flatbed #980833 10/23/2013 11:00 PM
I was worried about the width of the running board where the fender attaches.
They mount on brackets extending from the frame.
Grease magnet
41flatbed #980936 10/24/2013 3:07 AM
I forgot about the difference of the front fenders. May fit, may not.
41flatbed #981088 10/24/2013 6:36 PM
Someone said that the only differences between 1-1/2 ton fenders and 1/2 ton fenders are the 1-1/2 ton fenders are cut out at the front edges to prevent the larger tires from rubbing when turning. I haven't been able to verify this.
Grease magnet
41flatbed #981103 10/24/2013 7:30 PM
check the resto pack, page 57 and others, there's more difference than just those front cuts, the big truck fenders are bigger
41flatbed #981207 10/25/2013 2:19 AM
I have a 51 3600 3/4 ton and had trouble with running boards. Mine were torn up badly and I tried to find aftermarket running boards for the 3/4 ton. I never did find any and had to rework the old ones. It took a while but I was able to reuse them. The running boards seem to be like rear 3600 brake drums, impossible to find!
41flatbed #981282 10/25/2013 11:12 AM
It looks like you only choice on reproduction 3/4 ton running boards is fiberglass. Same material that is used for repo rear valance (deflector) on 47-55 panel body trucks.
41flatbed #981580 10/26/2013 3:58 PM
If I'm not mistaken, the 1.5 ton running boards hang lower.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
41flatbed #981677 10/27/2013 12:52 AM
They may hang lower. I need to compare the running board supports,
or at least find the specs for both.
Grease magnet
Where do you get the fiberglass ones?
1949 Chevy 3600
Any vendor that carries parts for these trucks, like Jim Carter, for sure.
My 46 GMC on Photobucket
