| | | Forums66 Topics128,119 Posts1,056,313 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#10246 04/03/2004 2:48 AM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Has anyone ever removed the exhaust manifold damper? Mine is now moving, but hangs up in the fully opened and closed positions. How do you get that thing apart without destroying it? I see the pin to pop the weight off, but I don't see anything that holds the damper to the shaft. The shaft slides back and forth freely so I just need to know what to take off or remove to get it apart. | | |
#10247 04/03/2004 4:40 AM | Joined: May 2003 Posts: 90 Member | | Member Joined: May 2003 Posts: 90 | Hi- I left the shaft and weight and cut the damper off the shaft and pulled it out with pliers. I never took the whole thing apart.
Good luck,
Brent | | |
#10248 04/03/2004 4:47 PM | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | That's called a "heat riser", and it's pretty important for quick warmup. It should have a bimetal spring that holds it in the closed position when cold, and opens as the manifold heats up. It routes exhaust gas under the intake during warmup, and then drops to the full open position when the spring heats up. Use lots of penetrating oil, and work it through the full range of motion repeatedly until it works freely with no hangups. The butterfly is spot-welded to the shaft on assembly, so replacing one is a hassle. I have fabricated a new flap, and carefully welded it into place on some restoration jobs. Brazing won't work, because of the heat involved in that area. Kroil is the best penetratant I've found for freeing up a heat riser. www.kanolabs.com Jerry
