1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#1024324 04/26/2014 2:07 AM
4 years ago I added a 12 volt aftermarket horn relay to the 50.
I few days ago the horn quit working so I replaced the relay.
it tested fine and worked.
well the horn went out again today.
quick power test to the terminal on the horn shows it works.
inspected the wires I could see and they look fine.
of course I cannot look at the mast wire.
What would cause 2 horn relays to go?
thanks
Bad ground? Could you bypass the mast wire with a jumper and see if that's your problem? Also you can do a continuity check for the mast wire.
Good luck
1946 1/2-Ton Chevy
You might have a bad relay. It happens. If the first relay worked for 4 years you have every thing in place so look at connections, corrosion and don't forget to look at the horn button pats as well. Are you running 1 horn or 2? The relay has to provide enough current to work both if you have them. With 2 horns see if you can get a relay rated at higher amps. Check one thing at a time and I bet you find it.
Steve H
My ground is good.
When it quit working I checked the ground, and tested the horn.
...one horn...
Might just be a bad new relay that worked 1 time.
You should be able to ground the mast wire connection and the relay should click. Did you do that?
1951 1 Ton Completed
Have not tried that yet
I would like to see if I can figure this out. Just spent another 18 bucks for a second relay last night. But have not installed it.
For this test
Can I do this with everything still hooked up?
Run a ground wire to the relay terminal for the mast wire?
Leave everything hooked up and use your jumper to go from ground to that terminal.
Ill give that a try after dinner tonight
I guess that is what the second post was stating, but when I read that post and checked the ground I was checking the ground from the terminal off the horn.
As stated earlier. Horn went out after 4 years of working fine.
Replaced with new relay.
Horn worked right after I replaced relay.
Next day
Horn did not work.
thanks you guys...
as soon as i got home today I had to test that relay
good ground to mast terminal on the relay. Horn BEEPED.
great
so I figured it the mast wire.
but just to be sure I removed the wheel and checked the plunger.
the wire inside the spring was missing.
so I found my original plunger.
popped it in and it worked...
thanks again you guys. I got tunnel vision with the relay and when it worked after I installed a new one I figured that was it.
here is my post on the other horn thread just a few days ago.
Originally Posted by DADS50
Originally Posted by oldbluetruck
I put a screw driver from the ring to the center and get a beep but nothing when I put it back together. I have the shop and assembled manuals, and have looked at all the sales books. Still no sound.
So, I thought that I am missing something
Sounds like its wired correctly if it works when you ground it.
Pop the Plunger out. There is a little spring inside that keeps contact with the bearing.
Are any of the parts new or reproduction?
kind of a dang moment for me.
Didn't even follow my own advise of a few days ago.
but I'm glad its working now.
I'm still wondering , what would cause the wire in the plunger to disappear?
its just a ground wire right?
no voltage on that wire?
I'm going to enjoy my dinner now.
You must be using the 6 volt version. I don't believe the 12 volt one has a wire. Just the spring.
Dennis
that's odd
the plunger I removed was purchased 4 years ago. it came complete with plastic jacket.
So I don't know for sure if it ever had a wire
the old one I installed last night was the original.
Horn still worked this morning
I had the plastic cased plunger one in my 6 volt system that I found it to be heating up. I also opened it and found that the thin spring was all there was. No wire. I ordered the plunger that is an open spring and has a wire down the middle. I hope it works.
Again, I am running a 6 volt system.
Dennis
Lets see...what is the better conductor? Steel spring or a proper copper conductor? Who cares..I just saved 18 cents on a 5 dollar part that I can sell for 12 dollars.
There has to be a better business model than that. I hope. Any way good fix and a good lesson for all of us.
Steve H
