| | | Forums66 Topics128,185 Posts1,057,281 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 17 New Guy | | New Guy Joined: Oct 2010 Posts: 17 | Hi guys I just pulled my vacuum diaphragm apart and found a huge hole, So now the trick is were to get one of these or use one from another type of truck or car for that matter that's close enough to do some mods to make it work............ ANYTHING PLEASE THIS DUMP IS A WORKING TRUCK!!!!!!! here is my dump its my pride and joy. | | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | Some of the Chevrolet dealers in the Midwest still had some NOS ones in stock just a few years ago. If you can get a Chevrolet dealer to do it, they can find NOS stock. The last one I bought was at a Chev dealer in Kansas. At that time he still had several of them on hand. | | | | | Joined: Oct 2010 Posts: 17 New Guy | | New Guy Joined: Oct 2010 Posts: 17 | Thank you Does anyone know what the part number is for that diaphragm and the little ring seal on shaft to keep oil from diff. getting in to vacuum unit or vice versa??? | | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | It looks like you could either have an Eaton 47638 which takes a GM 2398285 or a Bendix 374451 which takes a 3847058 GM. Are there any markings on the vacuum unit you have? | | | | | Joined: Oct 2010 Posts: 17 New Guy | | New Guy Joined: Oct 2010 Posts: 17 | | | | | | Joined: Feb 2004 Posts: 29,881 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,881 | Last resort- - - -make a diaphragm. A piece of fabric-reinforced rubber gasket material the appropriate thickness can be cut to the shape of the old diaphragm and attached to the mechanical linkage in the center. If it's riveted instead of bolted together, any good machinist can drill and tap the shaft to accept a center bolt and some flat washers. Just be sure to Loctite the bolt that holds the assembly together. I used to make diaphragms for pneumatic valves that way frequently when I was a maintenance man for E&J Gallo winery. Jerry
| | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | | | | | | Joined: Oct 2009 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 41 | I know this is past your prime...but I just bought a complete used diaphragm from Holst Truck in Idaho. I also purchased a NEW rubber diaphragm ($55)from Inland Truck Parts in Billings, MT.
| | | | | Joined: Oct 2010 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 32 | I know this is long after the original thread, but I happened to be looking for information on repairing the two speed diff in my 1957 Chevy 6100 Wrecker. I've been told by the shop that the diaphragm is brittle and cracked. I did find a place that has reproduction diaphrams. http://www.rebuildersenterprises.com/http://www.ebay.com/itm/2-SPEED-REAR-AXLE-DIAPHRAGM-GM-3847058-BENDIX-374451-/172542577743GM 3847058 2 SPEED DIAPHRAGM This is a brand new diaphragm manufactured for www.rebuildersenterprises.comFits GM 2 speed rear axles, Also replaces Bendix 374451. O.D. is approx 7" I.D. is approx 3" To see if this unit will fit your application or for technical assistance, feel free to call 800-489-9860. Rebuilders Enterprises, Inc. is Illinois' Original Remanufacturing Company | | |
