3 members (klhansen, J Lucas, 1 invisible),
50
8
Mod | | | Forums66 Topics128,010 Posts1,055,299 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | My horn on the 48 doesn't work. I believe it is at the steering wheel button. I also think it is the ground.
Is there a large washer in the mix for grounding? Thanks
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Maybe the wire on the horn ring wire came broke off
http://www.oldchevytrucks.com/cart/product.asp?prodid=EL109&i=9774|||||
Drew
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I put a screw driver from the ring to the center and get a beep but nothing when I put it back together. I have the shop and assembled manuals, and have looked at all the sales books. Still no sound.
So, I thought that I am missing something
| | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | Did you paint anything in area of the upper column bearing? A lot of these problems are caused by the paint not allowing the ring to ground to the bearing (it has the ground wire attached to it). Carl
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | No paint. Don't look like a rust problem either. Could I be missing a washer for the ground?
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Is the washer behind the plate a special one?
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | DADS50: Do you have a horn relay? Usually mounted to the voltage regulator. That might be the problem. You should have volts on the horn. The button on the wheel is the ground. So volts on the horn? Volts at the relay (if you have one) and volts at the plunger. One step at a time. And if the relay works again if you have one and the horn button makes a good ground then all that is left is the horn. And it made noise so it could be adjusted. There is an adjustment inside that can be made if it just gives a "bark" and quits you can try that. http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm1233.htm
Steve H
| | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | On DADS50 post above, the photo (this thing) you notice it is two pieces. On mine, I had to run some folded sandpaper between the two pieces. Then it worked fine. It was not making connection due to a light coat of rust.
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Thanks for the pictures. I will go through the whole thing and make sure it is put together right. And use some fine sand paper.
Thank you
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Thank you Steve. I will look into the voltage. I do have a relay. Maybe wired wrong.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I put a screw driver from the ring to the center and get a beep but nothing when I put it back together. I have the shop and assembled manuals, and have looked at all the sales books. Still no sound.
So, I thought that I am missing something Sounds like its wired correctly if it works when you ground it. Pop the Plunger out. There is a little spring inside that keeps contact with the bearing. Are any of the parts new or reproduction? | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Nice catch from DADS50. I forgot about that little bit of braid between the button, inside the spring to the contact. I soldered mine back together. and it worked just fine. I hope it is as easy for the OP.
Steve H
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I got the horn button working. Now all there is is a click under the hood. I don't have a horn relay.
| | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | If the horn is clicking it may be adjusted and come to life. It may have some corrosion on the contacts and they can be cleaned. If you have a single horn it will work without a relay, it will work better with one but it is not mandatory. Take the horn apart and see what you have and how it is adjusted. Not too hard and if you fix it you will feel good.
Steve H
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | It comes down to the plunger at the horn button. This is a new one. Are these buttons different between 6 and 12 volt.
Thanks to all for your help
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I ordered that plunger last night.
What I found is the other plunger (enclosed in plastic) contains a thin spring, was only passing a smaller voltage (small/thin spring), and heated up. I guess this is why the horn would only click when it was in place but would beep when I grounded the ring with a screw driver.
Thanks again.
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I put the 6 volt plunger in and the horn works
| | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | I don't believe the spring should be getting hot, as the current is carried by the wire running in the center of that plunger assembly. I'm guessing that your problematic plunger assembly has a bad center wire, forcing the current to flow through the spring. I don't know why Classicparts lists it as 6 volt only. Jim Carter doesn't make that distinction on the very same part. If there were a difference between a 6 volt and 12 volt plunger, I would think that a 6 volt plunger would have a heavier gauge center wire and work just fine on 12 volts. My assumption is based on the difference in 6 volt vs 12 volt wiring harnesses and battery cables. 6 volt wires are larger in diameter. Carl
