Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (Guitplayer, 55shaker, 2-Ton, Stovebolt48), 41 guests, and 2 robots.
Topics128,018
Posts1,055,259
Members48,417
#1024090 04/25/2014 2:21 AM
I thought I would post this in case anyone had problems with their straight six running rough (in my case a 1955 first series 235).
My engine vibrated a lot but would start right up. It sucked a lot of gas, I knew this because the truck was not on the road yet and my gas tank was an "IV" bottle. I figured the carburetor must be overfilling and dumping too much gas into the intake.
I ordered a carburetor rebuild kit and replaced the accelerator pump, the float needle and seat, and one gasket. The truck seemed to run better and I figured I might as well set the timing. Well I could not get the light to trigger on the number one cylinder. I thought maybe the light was bad and then I realized that the number one cylinder wasn't firing. I removed the distributor cap and found it to be horribly worn on the inside. I had an old spare and put it on. The truck ran pretty darn good :-)
I thought for good measure that I should get a new cap. You can get them at Autozone for about $9.00. When I put the new cap on I was amazed at how smooth the engine was! (the rotor, points, and condenser were already new). It is really quiet too.
The moral of the story is if your engine is running rough check to make sure the float is shutting off the gas and that the float level is set correctly and by all means get a new distributor cap. It can make a huge difference :-)
Joe
1955 First Series 3100
Thanks Joe. Was that a Rochester 2 bbl? Any tricks on that rebuild kit or pretty straightforward? I'm guessing the needle valve adjustments or in the shop manual or the kit?
Allen
1974 Stingray Corvette
It was a Rochester 1 bbl. The kit has a lot of little parts for a bunch of different carburetors but the only things I found useful was the accelerator pump and the float shut off. Float height is 1-9/32 closed and 1-3/4 open as measured from the top half of the carburetor (with gasket) to the top of the float. Its also in the instructions that come with the kit.
Joe
P.S. yes the kit was real easy
Plug wires are also very important.
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
Mendonjo, did you ever get to check the timing??? Was going to recommend fine tuning that timing with a vacuum gauge. You will be surprised how much better you can tune your motor.
1946 1/2-Ton Chevy
C Online: Content
Geez,
It's been 10+ years since I've touched my plugs, wires, cap, points. Maybe one of these days.....when it quits running so well. :-)
Craig
