1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#102405 09/04/2007 12:29 AM
I've checked all of the posts, but I can't seem to find one that fits the problem I'm having, so here goes. This is a '72 GMC pickup. When the tank is full, the gauge reads 1/4-tank. It drops as the fuel level goes down, so it functions that far at least. I replaced the fuel sending unit. Same issue with the new one. Only goes to 1/4 tank when the tank is full. If I disconnect the wire to the sending unit, the gauge goes to full. Reconnected the gauge goes back to 1/4 tank on a full tank. I added a ground strap from the fuel tank to the frame. Didn't change anything. I pulled the ground from the battery and cleaned that terminal connection. No change. I tried raising the arm on the sending unit with the wire connected and the unit grounded. If I raise it all the way up, the gauge goes to about 1/2 tank and that's all. I'm guessing at this point that it has to be the gauge. Since this is a '72, I'm not sure how the gauge is wired. It may be a circuit board (I can't see the back side of the gauges from under the dash). Any suggestions anyone? Any help would be appreciated. Thanks.
#102406 09/04/2007 1:15 PM
My bet would be the sending unit, I am not sure what they cost for a 72 but they usualy are not that much to replace.
Ed
#102407 09/04/2007 1:35 PM
as Ed stated ..
did you check to make sure it isnt STUCK?
1952 Chevy Shortbed
Photos in Photobucket
#102408 09/04/2007 1:36 PM
the Float i mean
1952 Chevy Shortbed
#102409 09/04/2007 11:48 PM
The float is not stuck and the sending unit is fine. It is brand new and functions properly. As I said, raising the arm all the way up (which would be higher than a full tank of gas) only brings the gauge to the 1/2 tank level.
#102410 09/05/2007 12:30 AM
Ex Hall Monitor
Ex Hall Monitor
One would assume a new sending unit is working OK. The best way to check is to check the resistance using a multi-meter. I don't know if 72 still used the 30 ohm sending unit/gauge set up or not. A check of your shop manual should tell you that. Assuming 30 ohms is correct and using 30 ohms as an example, if the sending unit reads 30 ohms with the float in the "full" position, the gauge should read full. If it doesn't and all connections and grounds are good the gauge would be at fault.
#102411 09/05/2007 12:35 AM
You may not have a good ground to the case of the fuel gauge. I believe that would cause the symptoms you exhibit.
