9 members (Gray_Ghost, cmayna, treegrower, Barney1951, UtahYork, Rusty Rod, TUTS 59, Rusty Heaps, 49choptop),
102
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,067 Posts1,055,877 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: May 2011 Posts: 55 | first a little background info. A friend of mine bought a 52 chevy 1.5 or 2 ton(not sure which as the vin was missing) a few years ago. we have since had it titled put kits in the rear wheel cylinders and new front wheel cylinders, and new master cylinder. The brakes have been bled and adjusted to were the shoes have a very slight drag. newly lined shoes and new rubber brake hoses installed. The problem in the pedal goes almost to the floor the first time it is pressed and only half a pedal after that. I cannot imagine what else could be the problem. Secondly the original engine would run but was wore slap out so we installed a full pressure 235 from another project. The 235 manifolds were toast so we installed the intake and exhaust from the original motor. The motor runs smooth as can be has good compession, does not burn oil or smoke. The problem is it is very sllllloooooowwwwwww. It takes a while for it to get to speed and is very slow to rev up. I have a 51 Ford f6 two ton that will literally run circles around this truck. What gives? Could the carb be too small? We installed the stepped sleeves to adapt the manifolds, checked timing, fuel pump is new, and new fuel lines. I am outta ideas | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | It would probably help to have the 235 intake manifold and carb. Did you do anything with the hydrovac? It needs to be part of the bleeding process. | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Sounds like what I went through on my '55 1st 6400. I ended up replacing everything including the Hydra-Vac unit. I had to retract the rear shoes all the way to get the brakes bled properly. I also had no power with my 261. Turned out to be a worn out distributor and a bad vacuum advance. Barry runs and stops like a champ now.
Bruce | | | | | Joined: May 2011 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: May 2011 Posts: 55 | When I replaced the vacuum advance I inspected the distributor for wear but I could have missed something. Also I am not sure if the truck originally came with a hydra-vac unit but it did not have one at the time of purchase so we did not install one. I will try retracting the rear shoes all the way in and then bleeding them. I am willing to try anything at this point. I will also try and locate the proper intake carb and exhaust manifolds and recheck the distributor. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | If its a 1 1/2 or 2 ton is should have a hydrovac. You have any pictures of your truck? | | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | If you can pump the brakes up with the pedal, then you still have air in the system. I don't know if a 52 2ton came with a hydrovac. Mine is a 57 2ton GMC. Had to buy a new hydrovac. It has 2 bleeders on it. Also mine has 2 wheel cylinders per wheel, that have to be bled. Did you bench bleed the master cyl.?
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You say you adjusted the brakes to a "slight drag". You can get some drag even when the adjustment are way off. Especially with new linings. Adjust them till you get a heavy drag & then back it off about 4 notches. You will get some rubeing but it will go away when they get seated. If your rear cyls. are mounted at an angle it is hard to get all the air out of them. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | A 51 Ford would have a flat head which is a lot quieter than a Chev with OH valves. You may just not be revving your Chev enough to gt the most out of it. However, in those days, a Ford with its V8 would out run a Chev, but a Chev would out pull a Ford on a hard hill. | | | | | Joined: May 2011 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: May 2011 Posts: 55 | I don't have any pics but it has 20" wheels, two wheel cylinders per side on the rear single speed axle and the front dust covers are bolted on. I know on the fords offered power brakes and two speed rears as an option on the 1.5 and 2 tons. Chevys I am not real sure about. The acceleration of the engine is just slow even when floored it takes a while to wind out even in second. But once at speed it will pull a 20ft gooseneck with a john deere A on it and pull small grades without slowing down. It just takes forever to get to 45 or 50mph. It's running about three foot of 2" pipe from the manifold going into a 3" tail pipe about 4' long and it sounds strong and amazing I might add. The exhaust manifold is Turing white, does that indicate a problem. The plugs are the proper color with no unusual deposits. I suspected air still in the lines but I have ran two big bottles of fluid through them. I made a fitting and bench bled the master cylinder. I might try using a vacuum gun. How much free travel should the brake have before the pedal firms up? | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Sounds like it's running lean. It would also help if you put smaller diameter exhaust pipe along with a muffler. I would also put a 235 intake and carb on if your going to be working it. | | | | | Joined: May 2011 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: May 2011 Posts: 55 | I will try and locate the correct manifolds as well as remove the distributor and check run out on the shaft, vacuum bleed the brake system and tighten the adjustment if bleeding does not work. Thanks for all the input. | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Billy W's got the same problem with his '59 Viking 60 bus.. He's not getting enough pressure to his rear brakes,and the 261 sounds good,and doesn't smoke. It has hardly any power. We fixed a couple of vacuum leaks,(carb base,vent tube at manifold),but the problem persists. Brakes require 15-18 lbs.,and we gauged his 261 at between 7-8 P.S.I. Next thing will be a compression check. I suspect the valves are carboned-up,so we're going to get the engine up to operating temp,and pour water through the carb,while throttle is set at a high idle. Same result as using trans.fluid,without the smoke,and it's a lot cheaper. I HOPE this works! We may have to have the valves ground,at which time,install hardened seats,to accomodate today's un-leaded fuel. I did this to my truck,and it runs like new!
