| | | Forums66 Topics128,130 Posts1,056,369 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 63 | Ok So I got a quick question.... How does the courtsey light turn on. I'm thinking turning the headlight swtich to the left should have done it but nothing... I have check the bulb and it's good. the wires are all hooked up...when I do turn my headlight switch it doesn't clickand just keeps turning a full 360 degrees so I'm confused... Oh and for those who don't know it's on my 1960 C10 -Danny
Thanks,as always -Danny
1960 C-10 Stepside,Longbox 235,4spd 3.90 diff.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | It should come on when the knob is turned to the left, and there should be a stop when it reaches the cntacts to turn it on. Sounds like there's something afoul in the switch itself, perhaps the tab that the shaft engages into is stripped out, not allowing it to turn with the shaft. Does the dimmer part work ok?
Bill Burmeister | | | | | Joined: Nov 2006 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 63 | yeah but intermently, you can tell it's not smooth I guess I'll be looking for a new switch then! thanks!
