0 members (), 133 guests, and 2 robots.
Topics128,157
Posts1,056,876
Members48,458
V
V Offline
Hi all,
I'm rebuilding a 1960 235. It's been in pieces in my garage for about 2 years and it's been fun trying to figure out how it came apart. It's almost done and ready to put it in my truck. The original motor had a brass extension on the temp sending unit. The head will accept the sending unit directly, or I can use just the adaptor. Do I need the adaptor? I would think the sending unit would work better without it. The engine is new, and I'll be working on the interior next. I've been reading a lot on this forum about mechanical systems. I think that is for earlier models, I'm going with the electric unit. So don't need original if modified works better.
Here's a pic of the adaptor: http://i459.photobucket.com/albums/qq320/Rickrestivo/Tempgagueadaptor.jpg
Thanks, Rick -
Proud of my taskforce!
1959 3600 long-bed. the ultimate work truck!
Rick Restivo
Valley Center, CA.
If the head will accept the sending unit as it is and seal, then that would be best. What year truck and what was the original engine?
Pretty common problem with later motor in old Chevy but the adaptors I've seen were just a short bushing not like your photo.
1946 1/2-Ton Chevy
If your 60 235 head has a 1/2 pipe thread for the sender
Then you might need this adapter from 1/2 pipe to 5/8 straight
...pic...
That's the NAPA part number.
I'm not sure but your pic looks like and adapter for 5/8 NF to 1/8 pipe for your electric sender?
Do you know what size the thread is in 235 head?
V
V Offline
1959 3600, the engine block and head are '60. The orig sending unit, the new one I just got today and the adaptor are all the same size and they all fit directly into the head so does a piece of 1/2" galv pipe. So, I'm assuming that is the size o f the hole in my head. I'll try putting the new sending unit directly into the head and see if it leaks.
Rick Restivo
Valley Center, CA.
V
V Offline
What's interesting is that I just received the sender I ordered. It seems to be a 1/2" pipe thread. Which is what I have in my head. I'll plug it all together and see what happens.
Rick Restivo
Valley Center, CA.
V
V Offline
Great comments all Thanks.
From what I gather from your responses, if it fits together without the adaptor I can put the sender directly in the head and it should be fine. My plan is to put the engine in the truck over Memorial day weekend. All that's left is cleaning and painting the manifolds and installing the "little stuff" Hopefully I'll be all smiles the Tuesday after. If not I'm sure you will be hearing from me.
Thanks again..
Rick Restivo
Valley Center, CA.
Yours is a 1959? Then it should have an electric sender with 1/2 pipe threads. Should screw directly into the head with no problems. Use very little sealer.
V
V Offline
Perfect!! Thanks Roy.
Rick Restivo
Valley Center, CA.
