6 members (Ponchogl, PAUL Berardi, dt235sd, Gray_Ghost, tclederman, JW51), 191 guests, and 7 robots.
Topics128,098
Posts1,056,167
Members48,436
#1023011 04/20/2014 12:25 PM
Looking for the inside side panels and headliner for the back of the panel truck. What do you guys use?
1950 one ton panel, 1959 half ton apache
1 Offline
There is no stock covers, there was a wood railing going down each side.
But you can get creative....
I am going to be using a hardwood veneer on my sides with a foam backing in between the posts.
...for the pieces between the supports I used some thin hard board from Lowes. Its temporary until I can do what I "want" to do.
I used a couple old panels for pattern but you could cut your own out of poster board/cardboard. Then I glued some fabric to it that I made when working for C&A. We made only fabric for the OEM car companies.
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/PanelInterior001-2.jpg
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/PanelInterior002-2.jpg
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/PanelInterior005-1.jpg
EDIT: The original overhead on my 52 panel was a "vinyl" like face with a "jute" type backing and was glued to the top between the ribs with some type of black asphalt goo. I pulled the old stuff down and will go back with a gray headliner.
Here are a couple pics. One is the face and back side of material.
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/000_0019.jpg
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/000_0020.jpg
