2 members (Kilted54, UtahYork),
72
Mod | | | Forums66 Topics128,196 Posts1,057,392 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 29 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 29 | Well I though I had this battle won until they showed up and I took them out of the box.
ES26L and ES26R DO NOT WORK, despite them being listed more than one place for this application.
Does anyone have a valid part number? Do the 1.5 ton interchange with the 2 ton?
1946 Chevy 2-Ton Rat Rod Wrecker
| | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy puppy, my Canadian parts book shows the GM p/ns as right 5837382, and the left as 5837381, I did try and cross these numbers at the Napa and Moog sites, but had no luck. | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | My parts book has the Tie Rod Ends listed as follows 1940-46 W, Y, M, O (hvy. duty) assy., left (4-3/4 long) (1-16 LH thd)...603935 1940-46 W, Y, M, O (hvy. duty) assy., right (4-11/16 long) (1-16 RH thd)...603934 Hope this helps, Mike B  | | | | | Joined: Jul 2009 Posts: 29 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 29 | I hope so too!
I didn't think finding parts for this truck would be this hard.
| | | | | Joined: Jul 2009 Posts: 29 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 29 | OK bad news. There is a set of the above mentioned part numbers on ebay and they are not going to work. It is showing those as an internally threaded tie rod end. Mine are externally threaded.
Also what are the W M Y O designations. My truck is a PW model.
| | | | | Joined: Jul 2009 Posts: 29 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 29 | OK found some papers I had stashed away.
All designations below are for 1-1/2 ton, 2 ton, bus, and COE Y=1941 M=1942, 1944, 1945 O=1946 interim P=1946 late
I'm not sure what the W model is.
I wonder if the P series had a different set of tie rod ends???
| | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | Puppy, W = 1940 Y = 1941 M = 1942 O = 1946 first design P = 1946 second design Q = 1947 I didn't know you had a 1946 second design, should have asked. The W in your prefix means you have a 160" wheel base. Check to see if your front axle has 3681101 forged in the I-Beam. If so you need the following tie rod ends. 1946-50 2-Ton, DUBL-DUTI, SBC...assy., left (use w/3681101 frgd. on "I" beam) (5 long) (1-16 L.H. thd)...609747 1946-50 2-Ton, DUBL-DUTI, SBC...assy., right (use w/3681101 frgd. on "I" beam) (5 long) (1-16 R.H. thd)...609748 Doesn't mention male or female thread... Hope this helps. Mike B  | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Filling Station - ML-20L and ML-20R
That is what I bought and installed on a '48 2 ton. worked perfect.
In case you need for future reference, I know looking for 2 ton parts is a job because most suppliers don't list anything over 1 tom;
ML-24 king pin set
FS-148 drag link repair kit
The description doesn't always sound like what it really is.
| | | | | Joined: Jul 2009 Posts: 29 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 29 | Mike B, I do indeed have the 3681101 front axle. However I have found several references to the 609747 and 609748 being listed as 1.5 ton units. This reference is from collectorsautosupply.com 1946-59 1 ½ TON TRUCK L.H. HEAVY DUTY TIE ROD END 609747 NOS $54 1946-59 1 ½ TON TRUCK R.H. HEAVY DUTY TIE ROD END 609748 NOS $54
Ebay has several of the same descriptions.
Not sure, maybe they interchange?
How do you have so much knowledge of these big bolts?
Thanks Jim Sears, I'll look into the FS parts.
| | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | puppy, The 609747 & 748 ends were also used on the Optional Heavy Duty 1-1/2 ton front axles, which is the standard axle on regular duty 2-ton trucks. That may be where the confusion come from. Do the pictures on ebay look right? You asked "How do you have so much knowledge of these big bolts?" Lots of books and years of research. Mike B  | | | | | Joined: Jul 2009 Posts: 29 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 29 | For future reference, Mike B nailed it with the info he provided.
609747 and 609748 are the correct part numbers for the 1.5 ton HD and the 2 ton tie rod ends.
Thanks!
