0 members (), 73 guests, and 2 robots.
Topics128,024
Posts1,055,390
Members48,422
#102295 08/25/2007 9:47 PM
Hi everyone. I'm working on my 72 Jimmy, and it seems my dual factory horns have quit. Took a voltage reading on the feed wire, and only have 6 volts. Could a faulty horn relay cause this??
(Both horns are now bad -- tried 12v - nada)
Also my gas gauge has quit responding...part of the same problem/circuit????
Thanks, Marc
#102296 08/26/2007 4:27 AM
it may, so could a bumb ground.
have you simply tried to operate the horns w/ a 12 v source other than your truck?
try a battery
probably not
Jim & Caroline
#102297 08/26/2007 4:04 PM
Thanks Caroline & Jim
It was a bad relay. Unbolted it from the firewall, and got 12v to the horns. Going to replace the relay.
Tried a direct 12v to the horns already, they're both dead. Reckon the 6volts/ground smoked 'em.
Thanks again.
