4 members (Shardean, Tstan7, 2 invisible),
94
Mod | | | Forums66 Topics128,022 Posts1,055,353 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 28 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 28 | Hi everyone. I'm working on my 72 Jimmy, and it seems my dual factory horns have quit. Took a voltage reading on the feed wire, and only have 6 volts. Could a faulty horn relay cause this?? (Both horns are now bad -- tried 12v - nada) Also my gas gauge has quit responding...part of the same problem/circuit???? Thanks, Marc | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | it may, so could a bumb ground. have you simply tried to operate the horns w/ a 12 v source other than your truck? try a battery
probably not
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Apr 2005 Posts: 28 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 28 | Thanks Caroline & Jim It was a bad relay. Unbolted it from the firewall, and got 12v to the horns. Going to replace the relay.
Tried a direct 12v to the horns already, they're both dead. Reckon the 6volts/ground smoked 'em. Thanks again. | | |
