0 members (), 102 guests, and 3 robots.
Topics128,186
Posts1,057,319
Members48,469
Well I though I had this battle won until they showed up and I took them out of the box.
ES26L and ES26R DO NOT WORK, despite them being listed more than one place for this application.
Does anyone have a valid part number?
Do the 1.5 ton interchange with the 2 ton?
1946 Chevy 2-Ton Rat Rod Wrecker
3B Offline
Hy puppy, my Canadian parts book shows the GM p/ns as right 5837382, and the left as 5837381, I did try and cross these numbers at the Napa and Moog sites, but had no luck.
My parts book has the Tie Rod Ends listed as follows
1940-46 W, Y, M, O (hvy. duty) assy., left (4-3/4 long) (1-16 LH thd)...603935
1940-46 W, Y, M, O (hvy. duty) assy., right (4-11/16 long) (1-16 RH thd)...603934
Hope this helps,
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
I hope so too!
I didn't think finding parts for this truck would be this hard.
OK bad news. There is a set of the above mentioned part numbers on ebay and they are not going to work. It is showing those as an internally threaded tie rod end. Mine are externally threaded.
Also what are the W M Y O designations. My truck is a PW model.
OK found some papers I had stashed away.
All designations below are for 1-1/2 ton, 2 ton, bus, and COE
Y=1941
M=1942, 1944, 1945
O=1946 interim
P=1946 late
I'm not sure what the W model is.
I wonder if the P series had a different set of tie rod ends???
Puppy,
W = 1940
Y = 1941
M = 1942
O = 1946 first design
P = 1946 second design
Q = 1947
I didn't know you had a 1946 second design, should have asked. The W in your prefix means you have a 160" wheel base.
Check to see if your front axle has 3681101 forged in the I-Beam. If so you need the following tie rod ends.
1946-50 2-Ton, DUBL-DUTI, SBC...assy., left (use w/3681101 frgd. on "I" beam) (5 long) (1-16 L.H. thd)...609747
1946-50 2-Ton, DUBL-DUTI, SBC...assy., right (use w/3681101 frgd. on "I" beam) (5 long) (1-16 R.H. thd)...609748
Doesn't mention male or female thread...
Hope this helps.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Filling Station - ML-20L and ML-20R
That is what I bought and installed on a '48 2 ton. worked perfect.
In case you need for future reference, I know looking for 2 ton parts is a job because most suppliers don't list anything over 1 tom;
ML-24 king pin set
FS-148 drag link repair kit
The description doesn't always sound like what it really is.
Mike B,
I do indeed have the 3681101 front axle. However I have found several references to the 609747 and 609748 being listed as 1.5 ton units.
This reference is from collectorsautosupply.com
1946-59 1 ½ TON TRUCK L.H. HEAVY DUTY TIE ROD END 609747 NOS $54
1946-59 1 ½ TON TRUCK R.H. HEAVY DUTY TIE ROD END 609748 NOS $54
Ebay has several of the same descriptions.
Not sure, maybe they interchange?
How do you have so much knowledge of these big bolts?
Thanks Jim Sears, I'll look into the FS parts.
puppy,
The 609747 & 748 ends were also used on the Optional Heavy Duty 1-1/2 ton front axles, which is the standard axle on regular duty 2-ton trucks. That may be where the confusion come from. Do the pictures on ebay look right?
You asked "How do you have so much knowledge of these big bolts?" Lots of books and years of research.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
For future reference, Mike B nailed it with the info he provided.
609747 and 609748 are the correct part numbers for the 1.5 ton HD and the 2 ton tie rod ends.
Thanks!
