| | | Forums66 Topics128,141 Posts1,056,485 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | I have some 1.5 and 2.5 ton truck axles that need some bearings. The originals are not made, so I am stuck with cross referencing.
Can anyone help walk me through this so I get the proper cones/races?
For my 1.5 ton truck banjo (Corporation) axle:
Rear wheel outer bearing GM-144527 Bearing roller, spherical, 2.6252 4.4688 O.D. 0.975 width
also has part number HYD-KD12051Z
Is that enough to find a modern bearing?
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Look it up @ Rockauto they're in all GM's just about. CHEVROLET C30 PICKUP (1982 - 1986) CHEVROLET C3500 PICKUP (1988 - 2002) CHEVROLET K30 PICKUP (1982 - 1986) CHEVROLET K3500 PICKUP (1988 - 1991) CHEVROLET P30 (1985 - 1999) CHEVROLET R30 PICKUP (1987 - 1988) CHEVROLET R3500 PICKUP (1989 - 1991) CHEVROLET V30 PICKUP (1987 - 1988) CHEVROLET V3500 PICKUP (1989 - 1991) GMC C3500 PICKUP (1982 - 2002) GMC K3500 (1982 - 1991) GMC P3500 (1985 - 1999) GMC R3500 PICKUP (1987 - 1991) GMC V3500 PICKUP (1987 - 1991) Please refer to catalog for application details.
| | | | | Joined: Jul 2007 Posts: 444 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 444 | They may have stopped making them but some do survive. Rear wheel outer bearing GM part # 144527 Roller Bearing Superseded to: GM part # 9412426 & is available at: Dotson Chevrolet Big Stone Gap, VA phone #: 276-523-0130 They have ( 1 ) - GM # 9412426 Marty's GMC Kingston, MA phone #: 781-585-7570 They have ( 2 ) - GM # 9412426 Friesen Chevrolet Sutton, NEB phone #: 402-773-5538 They have ( 1 ) - GM # 9412426 on ebay: just type in the search box: 9412426 There are ( 3 ) # 9412426 bearings on ebay now Here's one for: $64.98 http://i669.photobucket.com/albums/...g%209412426/9412426_NOS__zps85708278.jpgHope this helps. George in New Jersey
| | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | Does it matter that none of the applications in the Timken catalog (I did download the 2013 full catalog) are not listed as the proper application?
None of my manuals have any later PNs than the GM-144527, so how 'confident' should I be that the new 9412426 will fit?
It looks like the 9412426 will fit a Tahoe sized truck. My truck GVW is about 2 tons more that that (11,000lbs Gross) and can tow another 3,000lbs
| | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | GM-9412426 Indirect Cross Interchange
So that does not look like a good fit
Looking at the Rockauto page the width is wrong: Width (in) 0.8661
My original bearing spec is 0.975 width
This is my problem... I cannot find a spec for spec bearing. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Rear wheel outer bearing GM-144527 Bearing roller, spherical, 2.6252 4.4688 O.D. 0.975 width also has part number HYD- KD12051Z
Is a valid # and available from Portland, OR - McGuire Bearing Company www.mcguirebearing.com › Contact Us › Branches‎ (800) 547-6045 Toll Free (503) 238-1570 Local
| | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | How did you find this? I looked through the PDFs that seemed appropriate and no HYD part numbers were listed. Also a site search found nothing.
KD12051Z as a part number is all over the place and do not match all 3 numbers I have from the parts manual:
National® - Taper Bearing Set Part Number: KD12051Z Cup Length=0.7411
Timken KD12051Z wrong width Cone / Cup Width (In): 1.431
This is my problem... evidently the part number got 'reused' and no longer matches the original specs. That's why I am trying to match a bearing by the actual dimensions... the PNs seem useless.
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | How did you find this? I looked through the PDFs that seemed appropriate and no HYD part numbers were listed. Also a site search found nothing.
This is my problem... evidently the part number got 'reused' and no longer matches the original specs. That's why I am trying to match a bearing by the actual dimensions... the PNs seem useless. I talked with a real parts person there and he confirmed your spec's to the 3rd decimal point from the first post... what can I tell ya?
| | | | | Joined: Jul 2007 Posts: 444 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 444 | I went to GM Parts WIKI Typed in GM # 144527 The part number YOU posted. Went to parts History Catalog Parts History catalog says, below: @photobucket http://i669.photobucket.com/albums/...209412426/Parts_History__zps361c086a.jpgI'd double check the part # or go by the stamped # on the bearing Are you sure # 144527 is the outer axle Bearing ? GP
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | go by the stamped # on the bearing from OP Rear wheel outer bearing GM-144527 Bearing roller, spherical, 2.6252 4.4688 O.D. 0.975 width also has part number HYD-KD12051ZInner or Outer aside... It sounded like this is the PN# off the bearing.
| | | | | Joined: Jul 2007 Posts: 444 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 444 | I sent an email to: Marty's GMC Dealership in Mass.
email to them:
My old Bearing is stamped: HYD - KD12051Z
My old bearing GM # 144527 was superseded to: GM # 9412426
Is the new # the same as the old bearing ?
Thank You, George
Answer from GMC Dealer:
Correct: 9412426 replaced 144527
GP | | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | When I look at the vehicles that the new part number applies to the 9412426 is used on vehicles that were rated for 50-60% of the GVW from what what my truck is.
My truck grosses at 11,000. A most of the trucks that this 'new' part number crosses to are in the 6-7000 GVW range.
EMPTY my truck is more than these trucks GROSS.
That's one thing that is confusing me... is it a valid concern? I would be running these bearings at 2x the current design use. Yes, I will load it up to 10k+ (it has a dump body and I plan on using it). | | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | Now this is confusing. I got an x-ref for Jim Carter part number MEB 944 for a 1.5 ton rear axle bearing.
This is like 1/2 the cost of what I am seeing for other bearings.
I'm not super confident for the source of the x-ref, they have been massively wrong before. | | | | | Joined: Mar 2010 Posts: 10,282 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,282 | I'd sell the truck and buy something easier for which to find parts.
| | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | I may be making it harder than it needs to be. I have done that on occasion.
| | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | "Answer from GMC Dealer:
Correct: 9412426 replaced 144527"
Yeah but GM doesn't make bearings and there are at least a six interchange part numbers for 9412426. Declo, SKF, National, Timken all list 9412426 in their interchange manual and none of them match the specs in the parts book for the axle I have.
Trying to figure it out. Anyone??
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | I didn't read this but maybe you did this and I just didn't see. But take a micrometer and measure the shaft and the bore and try to find them by a size chart. Some of the larger cities have bearing houses that might pay you to look at or go to.
Timken does have a size chart so you can use the size of ther bearing to find the one that matches. But you may already have that. | | | | | Joined: Mar 2010 Posts: 10,282 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,282 | I may be making it harder than it needs to be. I have done that on occasion. P-man, with Chevrolet's habit of using the same parts through several generations of vehicles, I wouldn't be surprised if the ones called for in the newer, lower GVW trucks were the same as what you are looking for. If they fit, I would run them. You will probably break a leaf spring end before you crush a bearing. Carl
