| | | Forums66 Topics128,079 Posts1,056,286 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2012 Posts: 72 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 72 | Hi, guys: While installing a new oak bed on my '53 resto-mod pickup, I noticed that one of the 2 wires for the gas tank sending unit is very loose. It attaches to a small brass pin and the previous owner has just crimped on a roundish wire connector. (The second wire is a blade-type connection and seems very secure.) There must be a better way to connect to that round brass pin. And I can only imagine the hassles of reconnecting it if it comes off after I've finished the oak bed. Thanks for your advice. | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Is it a push type like the brake light switch? They work well if they are correct for the pin.
Steve H
| | | | | Joined: Dec 2012 Posts: 72 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 72 | Hi, Steve. I just sent you a couple of photos by email. Sorry but not sure how to attach them here on the forum. John | | | | | Joined: Dec 2012 Posts: 72 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 72 | A friend has suggested soldering the wire to the brass pin and using a heat-shrink sleeve over it all. How does that sound? | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | That is the wrong connector. The wire part is all you need. But I can't find a picture so this is from a parts house. http://www.oreillyauto.com/site/c/d...h_N0318_-1_-1&pt=N0318&ppt=C0092Like I said all you need is the part with the wire pigtail. I hope this helps. It is not expensive and you do get a new heating element if you can use it. Any way The same connector is used on the brake light switch and the lighter. And it will work for your sending unit. Mine is threaded so It took a minute to figure what you had. The E mail pics were very helpful.
Steve H
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You can buy a pack of crimp-on bullet connectors for a lot less than buying a lighter to only use the wire. Plus you can be sure the connector is the right size. | | | | | Joined: Dec 2012 Posts: 72 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 72 | Thanks, guys. Great advice here, as always!
John | | |
