5 members (GMCJammer51, DuckRancher, Peggy M, 49nut, 1 invisible), 118 guests, and 1 robot.
Topics128,110
Posts1,056,245
Members48,437
Hi, guys:
While installing a new oak bed on my '53 resto-mod pickup, I noticed that one of the 2 wires for the gas tank sending unit is very loose.
It attaches to a small brass pin and the previous owner has just crimped on a roundish wire connector. (The second wire is a blade-type connection and seems very secure.)
There must be a better way to connect to that round brass pin. And I can only imagine the hassles of reconnecting it if it comes off after I've finished the oak bed.
Thanks for your advice.
Is it a push type like the brake light switch? They work well if they are correct for the pin.
Steve H
Hi, Steve. I just sent you a couple of photos by email. Sorry but not sure how to attach them here on the forum.
A friend has suggested soldering the wire to the brass pin and using a heat-shrink sleeve over it all. How does that sound?
That is the wrong connector. The wire part is all you need. But I can't find a picture so this is from a parts house.
http://www.oreillyauto.com/site/c/d...h_N0318_-1_-1&pt=N0318&ppt=C0092
Like I said all you need is the part with the wire pigtail. I hope this helps. It is not expensive and you do get a new heating element if you can use it. Any way The same connector is used on the brake light switch and the lighter. And it will work for your sending unit. Mine is threaded so It took a minute to figure what you had. The E mail pics were very helpful.
Steve H
You can buy a pack of crimp-on bullet connectors for a lot less than buying a lighter to only use the wire. Plus you can be sure the connector is the right size.
Thanks, guys. Great advice here, as always!
