| | | Forums66 Topics128,175 Posts1,057,055 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 374 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 374 | Have any of you fine Stovebolters ever replaced a '54 or early '55 dash with an earlier dash (47 - 53). If so, can you describe any issues and also provide pics if you have them? This is for a friend of mine with a '54 cab who wants to go with the earlier dash. His biggest concern is the curvature of the top of the '54 dash (due to the one piece glass) versus the 'point' of the earlier dash due to the two piece glass. Thanks for any help in advance... design. Wokka wokka  | | | | | Joined: Mar 2010 Posts: 10,301 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,301 | Anything can be done. The question is always, how good are you at fabrication, and has your mother ever had you checked for sanity, and what were the results?  Why not sell the 54 cab and buy an earlier cab? I have replaced a 52 dash and it was a major PIA. I can only imagine the problems putting the earlier dash in a later cab. BTW, if I had to do it over, I would have scrapped the 52 cab and looked for a better one to start with. Carl
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Have to agree with Carl here, complete dashboard replacements in AD's is a lot of work. I have sold quite a few to people and just hogging the old one out is a lot of work! | | | | | Joined: Mar 2008 Posts: 374 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 374 | This is an already complete, beautiful, running truck where the owner is just not happy with the dash. It was altered by a previous owner and '54 early '55 dashes are as hard to find as hen's teeth. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | It is not a bolt in situation. The dashes are spot welded in and it is a big job to drill spot welds to take them out. | | | | | Joined: Mar 2008 Posts: 374 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 374 | The thought was perhaps 'grafting in' the older dash to the new one, leaving the original lip near the front glass. I appreciate the responses and will pass them along. Thanks S.B.s! | | | | | Joined: Mar 2010 Posts: 10,301 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,301 | The thought was perhaps 'grafting in' the older dash to the new one, leaving the original lip near the front glass. I appreciate the responses and will pass them along. Thanks S.B.s! That would probably be an easier way to go if you have good welding skills.
