3 members (moparguy, texas46, Gray_Ghost), 191 guests, and 3 robots.
Topics128,108
Posts1,056,236
Members48,437
I have some 1.5 and 2.5 ton truck axles that need some bearings. The originals are not made, so I am stuck with cross referencing.
Can anyone help walk me through this so I get the proper cones/races?
For my 1.5 ton truck banjo (Corporation) axle:
Rear wheel outer bearing
GM-144527 Bearing roller, spherical, 2.6252 4.4688 O.D. 0.975 width
also has part number HYD-KD12051Z
Is that enough to find a modern bearing?
Look it up @ Rockauto they're in all GM's just about.
CHEVROLET C30 PICKUP (1982 - 1986)
CHEVROLET C3500 PICKUP (1988 - 2002)
CHEVROLET K30 PICKUP (1982 - 1986)
CHEVROLET K3500 PICKUP (1988 - 1991)
CHEVROLET P30 (1985 - 1999)
CHEVROLET R30 PICKUP (1987 - 1988)
CHEVROLET R3500 PICKUP (1989 - 1991)
CHEVROLET V30 PICKUP (1987 - 1988)
CHEVROLET V3500 PICKUP (1989 - 1991)
GMC C3500 PICKUP (1982 - 2002)
GMC K3500 (1982 - 1991)
GMC P3500 (1985 - 1999)
GMC R3500 PICKUP (1987 - 1991)
GMC V3500 PICKUP (1987 - 1991)
Please refer to catalog for application details.
Give me ambiguity
or give me something else
' Offline
They may have stopped making them
but
some do survive.
GM part # 144527 Roller Bearing
Superseded to: GM part # 9412426
is available at:
Dotson Chevrolet
Big Stone Gap, VA
phone #: 276-523-0130
They have ( 1 ) - GM # 9412426
Marty's GMC
Kingston, MA
phone #: 781-585-7570
They have ( 2 ) - GM # 9412426
Friesen Chevrolet
Sutton, NEB
phone #: 402-773-5538
on ebay: just type in the search box: 9412426
There are ( 3 ) # 9412426 bearings on ebay now
Here's one for: $64.98
http://i669.photobucket.com/albums/...g%209412426/9412426_NOS__zps85708278.jpg
Hope this helps.
George
in
New Jersey
1954 3600
Now cruising in
The Passing Lane
page 135/136
://www.timken.com/en-US/products/Documents/Automotive_Aftermarket_Bearing_Seal_Application_Catalog_1989_older.pdf
page 6/7 and 31/32
http://www.timken.com/en-US/products/Documents/Medium-Duty-Apps-Buyers-Guide-2010.pdf
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Does it matter that none of the applications in the Timken catalog (I did download the 2013 full catalog) are not listed as the proper application?
None of my manuals have any later PNs than the GM-144527, so how 'confident' should I be that the new 9412426 will fit?
It looks like the 9412426 will fit a Tahoe sized truck. My truck GVW is about 2 tons more that that (11,000lbs Gross) and can tow another 3,000lbs
GM-9412426 Indirect Cross Interchange
So that does not look like a good fit
Looking at the Rockauto page the width is wrong:
Width (in) 0.8661
My original bearing spec is 0.975 width
This is my problem... I cannot find a spec for spec bearing.
Is a valid # and available from
Portland, OR - McGuire Bearing Company
www.mcguirebearing.com › Contact Us › Branches‎
(800) 547-6045 Toll Free (503) 238-1570 Local
Give me ambiguity
How did you find this? I looked through the PDFs that seemed appropriate and no HYD part numbers were listed. Also a site search found nothing.
KD12051Z as a part number is all over the place and do not match all 3 numbers I have from the parts manual:
National® - Taper Bearing Set Part Number: KD12051Z Cup Length=0.7411
Timken KD12051Z wrong width Cone / Cup Width (In): 1.431
This is my problem... evidently the part number got 'reused' and no longer matches the original specs. That's why I am trying to match a bearing by the actual dimensions... the PNs seem useless.
I talked with a real parts person there and he confirmed your spec's to the 3rd decimal point from the first post... what can I tell ya?
Give me ambiguity
' Offline
I went to GM Parts WIKI
Typed in GM # 144527
The part number YOU posted.
Went to parts History Catalog
Parts History catalog says,
below:
@photobucket
http://i669.photobucket.com/albums/...209412426/Parts_History__zps361c086a.jpg
I'd double check the part #
or
go by the stamped # on the bearing
Are you sure # 144527 is the outer axle Bearing ?
GP
1954 3600
Now cruising in
The Passing Lane
' Offline
This GM truck catalog
calls GM # 144527
a INNER WHEEL BEARING
You say, it's an outer.
I'm stumped !
Pic@photobucket
http://i669.photobucket.com/albums/...ng%209412426/AxleBearing_zps36518b5e.jpg
GP
1954 3600
Now cruising in
The Passing Lane
from OP
Inner or Outer aside... It sounded like this is the PN# off the bearing.
Give me ambiguity
' Offline
I sent an email to:
Marty's GMC Dealership in Mass.
email to them:
My old Bearing is stamped: HYD - KD12051Z
My old bearing GM # 144527
was superseded to: GM # 9412426
Is the new # the same as the old bearing ?
Thank You,
George
Answer from GMC Dealer:
Correct: 9412426 replaced 144527
GP
1954 3600
Now cruising in
The Passing Lane
When I look at the vehicles that the new part number applies to the 9412426 is used on vehicles that were rated for 50-60% of the GVW from what what my truck is.
My truck grosses at 11,000. A most of the trucks that this 'new' part number crosses to are in the 6-7000 GVW range.
EMPTY my truck is more than these trucks GROSS.
That's one thing that is confusing me... is it a valid concern? I would be running these bearings at 2x the current design use. Yes, I will load it up to 10k+ (it has a dump body and I plan on using it).
Now this is confusing. I got an x-ref for Jim Carter part number MEB 944 for a 1.5 ton rear axle bearing.
This is like 1/2 the cost of what I am seeing for other bearings.
I'm not super confident for the source of the x-ref, they have been massively wrong before.
I'd sell the truck and buy something easier for which to find parts.
I may be making it harder than it needs to be. I have done that on occasion.
"Answer from GMC Dealer:
Correct: 9412426 replaced 144527"
Yeah but GM doesn't make bearings and there are at least a six interchange part numbers for 9412426. Declo, SKF, National, Timken all list 9412426 in their interchange manual and none of them match the specs in the parts book for the axle I have.
Trying to figure it out. Anyone??
I didn't read this but maybe you did this and I just didn't see. But take a micrometer and measure the shaft and the bore and try to find them by a size chart. Some of the larger cities have bearing houses that might pay you to look at or go to.
Timken does have a size chart so you can use the size of ther bearing to find the one that matches. But you may already have that.
P-man, with Chevrolet's habit of using the same parts through several generations of vehicles, I wouldn't be surprised if the ones called for in the newer, lower GVW trucks were the same as what you are looking for. If they fit, I would run them. You will probably break a leaf spring end before you crush a bearing.
Carl
