Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (2-Ton, Peggy M, Youngin' Tut 59, Jon G), 36 guests, and 7 robots.
Topics128,010
Posts1,055,303
Members48,419
#1020560 04/09/2014 4:51 PM
My horn on the 48 doesn't work. I believe it is at the steering wheel button. I also think it is the ground.
Is there a large washer in the mix for grounding?
Dennis
oldbluetruck #1020566 04/09/2014 5:38 PM
Maybe the wire on the horn ring wire came broke off
http://www.oldchevytrucks.com/cart/product.asp?prodid=EL109&i=9774|||||
Drew
oldbluetruck #1020751 04/10/2014 3:52 PM
I put a screw driver from the ring to the center and get a beep but nothing when I put it back together. I have the shop and assembled manuals, and have looked at all the sales books. Still no sound.
So, I thought that I am missing something
Dennis
oldbluetruck #1020911 04/11/2014 3:04 AM
Did you paint anything in area of the upper column bearing? A lot of these problems are caused by the paint not allowing the ring to ground to the bearing (it has the ground wire attached to it).
Carl
oldbluetruck #1020917 04/11/2014 3:25 AM
No paint. Don't look like a rust problem either. Could I be missing a washer for the ground?
Dennis
oldbluetruck #1021562 04/14/2014 3:18 AM
Is the washer behind the plate a special one?
Dennis
oldbluetruck #1021563 04/14/2014 3:24 AM
oldbluetruck #1021648 04/14/2014 5:18 PM
DADS50: Do you have a horn relay? Usually mounted to the voltage regulator. That might be the problem. You should have volts on the horn. The button on the wheel is the ground. So volts on the horn? Volts at the relay (if you have one) and volts at the plunger. One step at a time. And if the relay works again if you have one and the horn button makes a good ground then all that is left is the horn. And it made noise so it could be adjusted. There is an adjustment inside that can be made if it just gives a "bark" and quits you can try that.
http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm1233.htm
Steve H
oldbluetruck #1021697 04/14/2014 9:32 PM
On DADS50 post above, the photo (this thing) you notice it is two pieces. On mine, I had to run some folded sandpaper between the two pieces. Then it worked fine. It was not making connection due to a light coat of rust.
57 GMC LCF 370
55 John Deere 40-W
59 John Deere 430-W
2000 GMC 4x4
56 John Deere 420-W
Pix on Photobucket
oldbluetruck #1022556 04/18/2014 4:18 AM
Thanks for the pictures. I will go through the whole thing and make sure it is put together right. And use some fine sand paper.
Thank you
Dennis
oldbluetruck #1022558 04/18/2014 4:21 AM
Thank you Steve. I will look into the voltage. I do have a relay. Maybe wired wrong.
Dennis
oldbluetruck #1022596 04/18/2014 1:41 PM
Sounds like its wired correctly if it works when you ground it.
Pop the Plunger out. There is a little spring inside that keeps contact with the bearing.
Are any of the parts new or reproduction?
oldbluetruck #1022782 04/19/2014 5:51 AM
Nice catch from DADS50. I forgot about that little bit of braid between the button, inside the spring to the contact. I soldered mine back together. and it worked just fine. I hope it is as easy for the OP.
Steve H
oldbluetruck #1024354 04/26/2014 4:28 AM
I got the horn button working. Now all there is is a click under the hood. I don't have a horn relay.
Dennis
oldbluetruck #1024394 04/26/2014 2:25 PM
If the horn is clicking it may be adjusted and come to life. It may have some corrosion on the contacts and they can be cleaned. If you have a single horn it will work without a relay, it will work better with one but it is not mandatory. Take the horn apart and see what you have and how it is adjusted. Not too hard and if you fix it you will feel good.
Steve H
oldbluetruck #1024479 04/27/2014 12:44 AM
It comes down to the plunger at the horn button. This is a new one. Are these buttons different between 6 and 12 volt.
Thanks to all for your help
Dennis
oldbluetruck #1024487 04/27/2014 2:08 AM
oldbluetruck #1024565 04/27/2014 4:07 PM
I ordered that plunger last night.
What I found is the other plunger (enclosed in plastic) contains a thin spring, was only passing a smaller voltage (small/thin spring), and heated up. I guess this is why the horn would only click when it was in place but would beep when I grounded the ring with a screw driver.
Thanks again.
Dennis
oldbluetruck #1026590 05/06/2014 6:33 AM
I put the 6 volt plunger in and the horn works
Dennis
oldbluetruck #1026810 05/07/2014 3:14 AM
I don't believe the spring should be getting hot, as the current is carried by the wire running in the center of that plunger assembly. I'm guessing that your problematic plunger assembly has a bad center wire, forcing the current to flow through the spring. I don't know why Classicparts lists it as 6 volt only. Jim Carter doesn't make that distinction on the very same part. If there were a difference between a 6 volt and 12 volt plunger, I would think that a 6 volt plunger would have a heavier gauge center wire and work just fine on 12 volts. My assumption is based on the difference in 6 volt vs 12 volt wiring harnesses and battery cables. 6 volt wires are larger in diameter.
Carl
