4 members (HandyAndy, klhansen, Gdads51, 52Carl), 103 guests, and 2 robots.
Topics128,062
Posts1,055,847
Members48,428
Does anyone have the secret of installing the horn button for the custom horns? I am switching over from the standard horn to the custom version.
I have tried all the tricks that I know.
I do know that the wiring is correct as I can make it work just not with the horn button installed.
Are you using the horn button that came with the truck or an after market button? Do you have a horn relay?
Yes, am using the correct deluxe/custom horn (for a 66). In my case I installed a 1970 steering column in my 64. I just like the looks of the 66 horn.
That said, me and my neighbor figured it out yesterday. Seems I was missing a piece. After we made one it worked like a champ.
I did take pics;
This is the order of assembly photo. On the paper is the orientation of the parts (note the direction of the concave flex plate).
http://s307.photobucket.com/user/Ru...tion_zps67877178.jpg.html?sort=3&o=3
This is the correct isolator and the dimension it is.
http://s307.photobucket.com/user/Ru...tors_zps09b84660.jpg.html?sort=3&o=2
This is the part that I was missing (kept the whole thing from working). I used an existing standard horn piece and cut it down.
http://s307.photobucket.com/user/Ru...iece_zps3a61291c.jpg.html?sort=3&o=1
Great. That should help some other people.
Great documentation for an always thorny problem!
Best wishes,
Les
