1 members (TooMany2count),
81
Mod | | | Forums66 Topics128,126 Posts1,056,354 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 374 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 374 | Is there any type of special chassis grease I should buy to grease my truck? 46 1/2 ton. I see red and black and all sorts in between. Also, for the parts that require a light oil (lube cups), what do you all recommend? 3 in 1? If there is already a thread about this I sure couldn’t locate it or find it in Tech Tips. Thanks! | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You can use a high temp lithium base grease for everything. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2008 Posts: 374 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 374 | Any suggestions on the 'light oil'? Thanks! | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | motor oil...same as you put in the engine. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | light oil: 10 to 30 weight (the owner's manual states light oil or engine oil)?
3-IN-ONE oil was commonly used?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, an engine oil was commonly used in the day, but note that was single weight non-detergent oil
Bill | | | | | Joined: Feb 2000 Posts: 5,221 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,221 | I would consider light oil to be anything other then gear oil. Any motor oil in the 0 to 40 weight range including straight 30 will work. One quart of 5W20 would last a long time for light oil lubricant.
I notice when changing oil in my mowers, the straight 30 weight is stringy and sticky where as the 10-30 poured right in. This could be a plus if you want the oil to cling to the shaft better. Straight Lucas oil additive would be a great lubricant for slow turning shafts, this stuff clings and strings to everything. I bought 30 weight oil for lawn mowers at my local ACE hardware for a fairly cheap price. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | "No. 20" (SAE 20) engine oil was recommended in the generator "oilers" in 1954 ("fill to the top"), and a "few drops" of SAE 10 oil on the felt wicking on the top of the distributor cam. | | | | | Joined: Mar 2008 Posts: 374 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 374 | | | |
