Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (1 invisible), 156 guests, and 2 robots.
Topics128,290
Posts1,058,562
Members48,492
As the title states, what sort of stand can I buy or make that will support a 235 and allow access to the bellhousing? I need to swap the 235 BH to the 216.
H Online: Content
I make a cradle out of 2X4's that supports the oil pan rails, and do plenty of cross bracing so it doesn't collapse sideways. You can make it tall enough to sit on the floor, but a shorter one that allows you to put the engine on a workbench makes more sense.
Just be sure you have a very sturdy workbench!
JRDamien,
There was post a while ago from Raleight58 Engine Cradle and there were several examples. There is also a very useful tech tips.
Here is one that I had made a few years ago.
picture , picture , picture
Bread
1939 Chevrolet 1/2-Ton
"There and back -- repeat"
I made one very much like Breads but put casters on the bottom so I could push it around the garage.
Pete
Gas Pumper
Gas Pumper
I just uploaded two engine stands to the bolt bucket. So the first two should be it. Edit: Seems to be the first pic and the very last one. The second one was made out of a 1950 pickup frame. It doesn't show it here, but there is a radiator mount and radiator and exhaust system even. I use it in conjunction with my start kart to test engines. The other one is a simple 1x1 square tubing cart that rolls around. I made 6 of them because that's how many engines I have. I need the ability to roll them around the shop. They have bell housings and even transmissions on some of them. The key is the exactly 9.5 inch spread between the rails so it sits very nicely on the oil pan ledge. Hope this helps!
http://www.speedprint.com/deves50/deveshowto.php
The engine cart how-to is there.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
Originally Posted by Bread
JRDamien,
Bread
Nice. Is something this low going to make it nearly impossible to get the bell housing (and the parts that must come off before the bell housing) off?
Where is the bolt bucket?
Gas Pumper
Gas Pumper
Click on the link below my signature that says More Pics in the Bolt Bucket. smile
Deve
The Think Tank
Deve,
So I went to your " more bolt pix "
On page 4, last pic, I see your engine stand. Is that the actual front end of a truck for your stand?
Holy crap is that sweet! I hate you...(kidding)
I'm going out side to set my garage on fire. Phil...
Phil
Gas Pumper
Gas Pumper
I worked in a single car unheated garage for years, so I am very pleased to have a better place now. Yes, its the front end of a burned out truck that was too fried to trust the steel, so I made an engine stand out of the front, a pickup bed trailer out of the back. Now and then you get information on parts that you don't really need, but... this was one of those.
Deve
The Think Tank
