0 members (),
117
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 291 'Bolter | | 'Bolter Joined: Jun 2011 Posts: 291 | This is my first time dealing with and learning about the torque tube set up on my 50 chevy 3100. I'm getting ready to install my rebuilt 59 235 and my rebuilt 50 chevy 3 speed. I'm picking up a new u joint tomorrow and I was reading some details about the torque tube set up. It is my understanding that the u joints in these trucks originally did not have needle bearings, they had bushings and they were lubricated by the oil contained inside the torque tube. My question is this, If I can get u joints for this torque tube that have needle bearings, why would I need the oil in the torque tube? Would this thing operate like a regular driveshaft if the u joints were upgraded? Please educate me further on this matter? My torque tube looks kind of beat up on the inside of the pivoting part where I have to figure out the seals and shims ordeal once I get the seals latter this week. I'm concerned that this thing is going to be a nasty, dripping issue on my completely clean truck. | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Hardshell
Short answer is yes you need oil in there. Even with needle bearings. One pint of oil to be exact. The marks are likely from a loose clip flipping around in there.
Get the shim kit and follow the shop manual of installing it. That's the best luck I've had. Heck you live close enough I can come by and help, but April is pretty busy!
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | My question is this, If I can get u joints for this torque tube that have needle bearings, why would I need the oil in the torque tube? Would this thing operate like a regular driveshaft if the u joints were upgraded? Both yokes of the u joint are supported by bronze bushings....one in the tube and the other in the back of the tranny. Lack of lubrication to these bushings is where u joint trouble starts IMO.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If you will be using the torque-tube, you cannot avoid oil reaching the enclosed u-joint. The oil in the u-joint housing comes from the transmission.
| | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Not to hijack this in any way,,where did you get your U-joint from? I have tried to get one for about a year now so if you found a source let us know.
Steve H
| | | | | Joined: Jun 2011 Posts: 291 'Bolter | | 'Bolter Joined: Jun 2011 Posts: 291 | From what you are saying Tim, there is no transmission seal that keeps the oil in the gear box separate from the u joint area, right? I don't like the design but I cant change now. I have been spending large sums of money and it is time to get this thing running. | | | | | Joined: Jun 2011 Posts: 291 'Bolter | | 'Bolter Joined: Jun 2011 Posts: 291 | It turns out that someone at the auto parts store was sadly mistaken. I have no u joint source yet Steve but I called my engine builder today and he told me about a place that might be able to make them or possibly have the correct part available. I'll be sure to share this source if all goes well tomorrow and I get the u joint that fits this thing. | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Unless the seal is bad in the top of the torque tube the oil is not lost out of the ball where the U joint runs, so any excess runs back in the tranny. If the seal is bad at the top of the torque tube, then oil leaks into the differential and it becomes overfilled.....
John | | | | | Joined: Dec 2011 Posts: 133 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 133 | There is a u-joint available on e-bay right now. Looks like new/old stock. Sit down before you look at the cost. $165
If you never tell a lie, you never need to remember what you said.
| | | | | Joined: Jun 2011 Posts: 291 'Bolter | | 'Bolter Joined: Jun 2011 Posts: 291 | Thank you John for more insight on how oil is supposed to flow ( and not flow in the drivetrain) I'm starting to see the whole picture. I ordered a new seal for the torque tube to keep oil away from the rear. I also ordered a tool to get that thing out but the tool is back ordered. I should know this truck pretty well by the time I get to turn the key and make something happen! | | |
