| | | Forums66 Topics128,078 Posts1,056,057 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 182 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 182 | Changing the rear axle end oil seals on a '46 Chevy 1/2 ton and was wondering if I'm putting them in right since the Timken ones I got don't look anything like the old ones, especially since the old ones are pretty wasted. I was thinking the the side of the seal that has the rubber flush with the metal goes to the outside. Is this right?
Thanks in advance. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | You should always go by the lip. The lip of the seal should point towards the oil side. | | | | | Joined: Aug 2010 Posts: 182 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 182 | Each of these seals has a double lip. Maybe it doesn't matter which way they go. I've always installed oil seals with the flush side out because I figure if you'd put the side that has the gap out it would just collect dirt in that gap. | | | | | Joined: Dec 2012 Posts: 16 'Bolter | | 'Bolter Joined: Dec 2012 Posts: 16 | I recently replaced the oil seals on my 48 3/4 ton, as you describe (part number visible when installed) | | |
