| | | Forums66 Topics128,080 Posts1,056,063 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 224 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 224 | Is the fuel line to pump hard piped in ,or does it need a rubber hose at the pump , I've got a rubber hose coming out of the cab . '55 235
" STUCK IN THE '50'S "
| | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | On my 49 I have a 6" rubber hose coming out of tank going into a hard line. Then a hard line into pump and from pump to carb. I would think a hard line from tank to pump will work loose over time due to flexing of the cab on chassis. I also installed an in-line filter in my hose at the tank.
Ed
| | | | | Joined: Jul 2013 Posts: 224 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 224 | Thanks , when I got the truck all that was missing and I wasn't sure about needing a rubber hose going into the pump ,.... now I know THANKS ... I'm installing a glass bowl filter right before the carbs..
| | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Recommend a filter right out of tank also, unless you have a new tank. Lots of crud can build up over time and the sooner you get it out the better. Less chance of pump contamination too!
Ed
| | | | | Joined: Jul 2013 Posts: 224 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 224 | Thanks , I ordered new tank yesterday ...looked on e-bay and could not find a filter that had connections for 5/16 fittings , that's what I wanted ,so I ordered a glass bowl filter ,when and if I find one I'll install it before the pump ( I don't like the filters that push on and use clamps ) .When I started I was going to try to use all the original parts . now after 8 mos. I'm using almost all new parts..
