1 members (78buckshot), 64 guests, and 3 robots.
Topics128,089
Posts1,056,004
Members48,430
#1020318 04/08/2014 3:51 PM
Is the fuel line to pump hard piped in ,or does it need a rubber hose at the pump , I've got a rubber hose coming out of the cab . '55 235
" STUCK IN THE '50'S "
On my 49 I have a 6" rubber hose coming out of tank going into a hard line. Then a hard line into pump and from pump to carb. I would think a hard line from tank to pump will work loose over time due to flexing of the cab on chassis. I also installed an in-line filter in my hose at the tank.
Ed
Thanks , when I got the truck all that was missing and I wasn't sure about needing a rubber hose going into the pump ,.... now I know THANKS ... I'm installing a glass bowl filter right before the carbs..
Recommend a filter right out of tank also, unless you have a new tank. Lots of crud can build up over time and the sooner you get it out the better. Less chance of pump contamination too!
Ed
Thanks , I ordered new tank yesterday ...looked on e-bay and could not find a filter that had connections for 5/16 fittings , that's what I wanted ,so I ordered a glass bowl filter ,when and if I find one I'll install it before the pump ( I don't like the filters that push on and use clamps ) .When I started I was going to try to use all the original parts . now after 8 mos. I'm using almost all new parts..
