Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (54farmtruck, UtahYork), 48 guests, and 6 robots.
Topics128,003
Posts1,055,244
Members48,418
#1020091 04/07/2014 5:18 PM
Hi, need to replace the Resistor Wire in my C10 ´62 (235cid)somebody in the past cut out this wire and replaced it with a normal wire...of course the contacts point last at least 3-4 months should I put an aftermarket external Resistor? In my country the only I can get in local shops are "made in china" 20ohms aprox.
Maybe in the future will put an DYI Electronic circuit to reduce the Current but I want to leave old school most of the truck!!
Thanks!!
Chrysler Stratus LE V6 1998
Chevrolet C10 235cid 1962
Ford Custom Tudor 300 272cid 1957
Puch SRA 150 1959
German62 #1020097 04/07/2014 5:53 PM
German62 #1020337 04/08/2014 5:48 PM
Many thanks John!!
Puch SRA 150 1959
German62 #1020855 04/10/2014 10:23 PM
Another good option is to find the resister on any old Chevy in a salvage yard. They almost never go bad. Clean it with brake cleaner check to make sure it isn't shorted, and use that. Very best wishes,
Les
German62 #1021216 04/12/2014 5:39 PM
In order to drop the voltage to the coil primary by approximately 4 volts, you're going to need a resistor measuring 1-1.5 ohms and capable of flowing 3-4 amps of current. That's going to be a pretty heavy-duty resistor that develops a lot of heat. Stovebolt points can only handle current flow of 5 amps or less, and 3.5-4 amps is a lot better. With the engine running and the charging system developing 14 volts or so, the ideal voltage at the coil + terminal is about 9.5 volts. If an original-equipment ignition resistor isn't available, I'd suggest running four 5-ohm resistors in parallel, with as high a wattage rating as possible, mounted in a position where they can get good airflow from the fan for cooling.
German62 #1022083 04/16/2014 12:13 PM
Hi Les, I still looking for an old resistor but I had no luck so far! Thanks Jerry for your tips, I´ll try to make a parallel arrange of 4 ceramic and wire resistors, I acquired a NOS Points (DODUCO "Made in Germany") is the best you can buy in my country!
German
Puch SRA 150 1959
