Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (jay d, 2 invisible), 54 guests, and 3 robots.
Topics128,009
Posts1,055,292
Members48,419
#1015737 03/20/2014 11:04 PM
I'm trying to identify the 235 in my 51 3100. I know it's not original.From the casting number I got that it is a 1958-1962 235. Also cast on the block is the code F29. Does that mean June 2 1959? Also the stamp on the distributor boss is F603B.I know F is Flint and I think 603 means June 3 (right?) but I can't find anything anywhere to identify the suffix code,the B. Anyone know what I have?Thanks---Jack
Jack,
Correct on all identifications.
F603B
F = Flint, MI
6 = June
03 = 3rd
B = 235 with Powerglide transmission
(passenger car engine - and, Powerglide engines had hydraulic lifters)
That's some valuable info. Thanks Tim---Jack
Hi guys I have a 1949 5 window I just picked up and also have the same problem block# is F318B an help please?
F= flint 3= march 18= 18th b= 235 with powerglide
http://s1055.photobucket.com/user/baldybenny/library/
1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
That was a easy one with Tims post.
All this stuff is easy once you learn the language. I'm glad there's folks here that can translate.---Jack
Thanks for all the great info guys real help me out!
I have a 235 which was in my 46 pickup when I purchased, the casting # is 3764476 and the stamped # is F512J. Can you help me identify?
3764476 was a truck block code from 1956 through at least 1961
F512J
F = Flint, MI assembly plant
5 = May
12 = 12th
J = 3100-3800 regular production truck (3-speed transmission)
That type/style of engine serial number was used from 1957 onwards.
If you want a date for the block/head, post the head date casting code and the block date casting code.
Thanks, I removed this running engine and trans. Replaced with 292 and T5. Rebuild still in progress.
