1 members (Hotrod Lincoln),
49
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2014 Posts: 161 Shop Shark | | Shop Shark Joined: Mar 2014 Posts: 161 | I'm trying to identify the 235 in my 51 3100. I know it's not original.From the casting number I got that it is a 1958-1962 235. Also cast on the block is the code F29. Does that mean June 2 1959? Also the stamp on the distributor boss is F603B.I know F is Flint and I think 603 means June 3 (right?) but I can't find anything anywhere to identify the suffix code,the B. Anyone know what I have?Thanks---Jack | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Jack, Correct on all identifications. F603B F = Flint, MI 6 = June 03 = 3rd B = 235 with Powerglide transmission (passenger car engine - and, Powerglide engines had hydraulic lifters) | | | | | Joined: Mar 2014 Posts: 161 Shop Shark | | Shop Shark Joined: Mar 2014 Posts: 161 | That's some valuable info. Thanks Tim---Jack | | | | | Joined: Mar 2014 Posts: 3 New Guy | | New Guy Joined: Mar 2014 Posts: 3 | Hi guys I have a 1949 5 window I just picked up and also have the same problem block# is F318B an help please? | | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | F= flint 3= march 18= 18th b= 235 with powerglide http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
| | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | That was a easy one with Tims post. http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
| | | | | Joined: Mar 2014 Posts: 161 Shop Shark | | Shop Shark Joined: Mar 2014 Posts: 161 | All this stuff is easy once you learn the language. I'm glad there's folks here that can translate.---Jack | | | | | Joined: Mar 2014 Posts: 3 New Guy | | New Guy Joined: Mar 2014 Posts: 3 | Thanks for all the great info guys real help me out! | | | | | Joined: Sep 2013 Posts: 3 New Guy | | New Guy Joined: Sep 2013 Posts: 3 | I have a 235 which was in my 46 pickup when I purchased, the casting # is 3764476 and the stamped # is F512J. Can you help me identify? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 3764476 was a truck block code from 1956 through at least 1961 F512J F = Flint, MI assembly plant 5 = May 12 = 12th J = 3100-3800 regular production truck (3-speed transmission) That type/style of engine serial number was used from 1957 onwards. If you want a date for the block/head, post the head date casting code and the block date casting code. | | | | | Joined: Sep 2013 Posts: 3 New Guy | | New Guy Joined: Sep 2013 Posts: 3 | Thanks, I removed this running engine and trans. Replaced with 292 and T5. Rebuild still in progress. | | |
