| | | Forums66 Topics128,277 Posts1,058,441 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | I have converted my 1949 3100 to front disc brakes and would like to use existing 16" tires and original hubcaps and trim rings . The rims are 6 lug . Does anyone know what rims will clear | | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | Try a search for this. Lots of ideas. Some have trimmed just a bit on the wheel and others have sourced new wheels. The new wheel issue is that 16 inch less than 8 inch wide is hard to find. With 6 lugs any way. Some new wheels will need to have clips installed for the hubcaps. Trim rings? I don't know.
Steve H
| | | | | Joined: Mar 2013 Posts: 165 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 165 | I have also seen were guys do some grinding, if you go NEW WheelSmiths wheels work work with disk brakes. | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | contacted thewheelsmiths.net , they seem to be able to do what I need Did a search here and found their website listed
thanks | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | You should be very happy with them. I got 5 wheels from them that accept modern radial tires and disc brakes AND they will either fix your existing hubcaps to accommodate their wheels, or if you don't have them, they will sell you the correct ones that work with their tires. You cant lose. And at about $94 a wheel or so, its very reasonable to know you have reliable wheels. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I have the wheelsmith artillery wheels on my suburban.Jim carter sells new hubcaps that are made to fit them. I'm very pleased with them.
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Jan 2013 Posts: 2,239 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,239 | hey guys, I just went through Tucker and got front disk brakes for my 51 3100. It required me to add a 1" spacer in order to get the rims to clear the disks. Tucker sells the spacer for $200 i think it was. I didnt have much choice since i don't have much metal laying here of the equipment to make it myself.
They told me that i could space it with washers to get the correct depth and that 3/8" is what they actually figured it out to be.
Chris | | | | | Joined: Jan 2013 Posts: 2,239 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,239 | forgot to mention, i am keeping the original rim on mine | | |
