Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Otto Skorzeny, Dakota Bob, TooMany2count, 1 invisible), 86 guests, and 4 robots.
Topics128,276
Posts1,058,440
Members48,490
I have converted my 1949 3100 to front disc brakes and would like to use existing 16" tires and original hubcaps and trim rings .
The rims are 6 lug .
Does anyone know what rims will clear
just-a-hacker
'49 3100 before '99
Try a search for this. Lots of ideas. Some have trimmed just a bit on the wheel and others have sourced new wheels. The new wheel issue is that 16 inch less than 8 inch wide is hard to find. With 6 lugs any way. Some new wheels will need to have clips installed for the hubcaps. Trim rings? I don't know.
Steve H
I have also seen were guys do some grinding, if you go NEW WheelSmiths wheels work work with disk brakes.
contacted thewheelsmiths.net , they seem to be able to do what I need
Did a search here and found their website listed
thanks
just-a-hacker
'49 3100 before '99
Gas Pumper
Gas Pumper
You should be very happy with them. I got 5 wheels from them that accept modern radial tires and disc brakes AND they will either fix your existing hubcaps to accommodate their wheels, or if you don't have them, they will sell you the correct ones that work with their tires. You cant lose. And at about $94 a wheel or so, its very reasonable to know you have reliable wheels.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
I have the wheelsmith artillery wheels on my suburban.Jim carter sells new hubcaps that are made to fit them. I'm very pleased with them.
Tim
1951 3100 Chevrolet
hey guys, I just went through Tucker and got front disk brakes for my 51 3100. It required me to add a 1" spacer in order to get the rims to clear the disks. Tucker sells the spacer for $200 i think it was. I didnt have much choice since i don't have much metal laying here of the equipment to make it myself.
They told me that i could space it with washers to get the correct depth and that 3/8" is what they actually figured it out to be.
Chris
forgot to mention, i am keeping the original rim on mine
