1 members (baldeagle), 43 guests, and 3 robots.
Topics128,037
Posts1,055,466
Members48,424
#101932 08/04/2007 9:43 PM
I have an am fm radioin my '51 1/2 ton. The static is ok when I'm idling, but the faster I go the worse it becomes.
I hear there is some "loop" thats suppose to eliminate the problem (something about the coil interfering with reception). Could someone tell me precisely the brand name and model of what I need to install, does it come with simple pictures and instructions, and is it easy enough to do without an engineering degree?
Thanks.
#101933 08/04/2007 11:32 PM
I think its called a condensor,,or resistor type spark plugs.
#101934 08/06/2007 12:03 AM
Easiest fix is probably going to be a set of resistor type plug wires. Don't forget to change the one from the center of the dizzy cap to the coil.
There are noise supressor capacitors that can be installed too. You can probably get these at Radio Shack.
#101935 08/06/2007 12:11 AM
Waldo,
Ah!! OK, thanks. I didnt have this problem tillI changed the plug wires. The originals probably were resistor type.
thanks.
#101936 08/06/2007 8:50 AM
Waldo nailed this one , I would bet a shiney new penny it is the wires.
1952 Chevy Shortbed
Photos in Photobucket
