7 members (Lightholder's Dad, Wickedbass, Christian, NJC, Hotrod Lincoln, baldeagle, 1955 1 Series), 59 guests, and 4 robots.
Topics128,017
Posts1,055,338
Members48,419
#1017180 03/26/2014 10:26 PM
Hello everyone, I want to install a ,Tripower set of carbs on my 235 motor, preferably Rochester 1b; Can anyone tell me where to find them? Thx, Your help is appreciated. Olgzr
bebop40 #1019239 04/03/2014 9:12 PM
Lots of vendors: Patrick's Antique cars/trucks, Speedway motors, Chevs of the 40s, they all have multi carb intakes. Finding three matched Rochesters will take some shopping, swap meets, ebay etc etc.
Good luck
1946 1/2-Ton Chevy
bebop40 #1019270 04/03/2014 11:38 PM
H Online: Content
Triple Trouble- - - -unless you install dummy carbs on the ends and just run on the middle one!
unlike dual carbs, you should set up tri carbs with progressive linkage. Run the engine on the center for the first 1/3 of the engine rpm and then start opening the ends.
Opening 3 carbs at lower rpm's causes very low and inefficient air flow through all the carbs.
