1 members (1955 1 Series),
64
Mod | | | Forums66 Topics128,169 Posts1,057,102 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 224 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 224 | I buying a new galvanized gas tank next week , I'm hearing I need SS lines . I'm using a filter . I would think steel would work ok .. What do you think ....
" STUCK IN THE '50'S "
| | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | Stainless is hard to work. Stiff, and a pain to flare. Not friendly at the fittings either. I would use steel or the copper-nickel stuff like brake lines. It won't rust like plain steel. But steel line is OK to.
Steve H
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Steel will out last you unless you are very young. | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | I used "Copperized Steel Coated With Galvanized Zinc" on my '65 C10. This is what OEM's use and it is very easy to work with, much easier than stainless, which I have used on other projects. "OE-type double wall copperized steel tubing coated with galvanized zinc for superior rust protection" http://www.jegs.com/i/JEGS-Performa...02/-1?parentProductId=757155#moreDetails | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Wanderer, the only reason I could think you're being told you need SS lines is because you could be at risk of galvanic corrosion (dissimilar metals). I don't think you would have any issue with steel though. | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | Wanderer, the only reason I could think you're being told you need SS lines is because you could be at risk of galvanic corrosion (dissimilar metals). I don't think you would have any issue with steel though. Interesting... but I am confused?  Wanderer states he is buying a "galvanized" tank, so it would be made of steel. Using stainless lines he would have ss to stl, thus a galvanic connection. Using steel lines he will have steel to steel, a non-galvanic connection. | | | | | Joined: Jul 2013 Posts: 224 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 224 | I read the instructions wrong (sorry about that ) It said Stainless steel fuel filter . Cletis I'm 70 so I'll be using zinc coated lines they should outlast me . lol....( by the way there's a rubber line about 6" long under the cab .
Again thanks for straightening me out I'll wear my glasses next time I read instructions ... No wonder I was confused ...
| | | | | Joined: Mar 2010 Posts: 10,307 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,307 | I'm 70 so I'll be using zinc coated lines they should outlast me . lol....( by the way there's a rubber line about 6" long under the cab . Keep your chin up Wanderer, you will very likely out live that rubber hose!
