6 members (TUTS 59, RLB, Otto Skorzeny, 52Carl, Gray_Ghost, ShopRag), 132 guests, and 2 robots.
Topics128,130
Posts1,056,714
Members48,454
#1018764 04/01/2014 9:38 PM
I buying a new galvanized gas tank next week , I'm hearing I need SS lines . I'm using a filter . I would think steel would work ok .. What do you think ....
" STUCK IN THE '50'S "
Stainless is hard to work. Stiff, and a pain to flare. Not friendly at the fittings either. I would use steel or the copper-nickel stuff like brake lines. It won't rust like plain steel. But steel line is OK to.
Steve H
Steel will out last you unless you are very young.
I used "Copperized Steel Coated With Galvanized Zinc" on my '65 C10. This is what OEM's use and it is very easy to work with, much easier than stainless, which I have used on other projects.
"OE-type double wall copperized steel tubing coated with galvanized zinc for superior rust protection"
http://www.jegs.com/i/JEGS-Performa...02/-1?parentProductId=757155#moreDetails
Wanderer, the only reason I could think you're being told you need SS lines is because you could be at risk of galvanic corrosion (dissimilar metals). I don't think you would have any issue with steel though.
My 46 GMC on Photobucket
Interesting... but I am confused? ohwell Wanderer states he is buying a "galvanized" tank, so it would be made of steel. Using stainless lines he would have ss to stl, thus a galvanic connection. Using steel lines he will have steel to steel, a non-galvanic connection.
I read the instructions wrong (sorry about that ) It said Stainless steel fuel filter . Cletis I'm 70 so I'll be using zinc coated lines they should outlast me . lol....( by the way there's a rubber line about 6" long under the cab .
Again thanks for straightening me out I'll wear my glasses next time I read instructions ... No wonder I was confused ...
5 Online: Content
Keep your chin up Wanderer, you will very likely out live that rubber hose! smile
