3 members (TUTS 59, Jon G, Joe H), 97 guests, and 3 robots.
Topics128,026
Posts1,055,402
Members48,422
#1018744 04/01/2014 7:00 PM
OK. Here's my problem. I have a '52 3100 with the original speedo in it. The tranny is a '54 SM420 4 speed. The speedo gear is in the tranny and the cable housing is connected but there is no end to the cable connecting it to the gear in the tranny. I can't seem to find a cable that specifies it's for a SM420 in the description at any of the normal parts locations (Classic, ..of the 40's..., Brothers, LMC, etc). Can anybody give me an idea what cable will fir the application and where I might find it? I appreciate the help.
1952 Chevy 3100
Semper Fi !
3 speed and 4 speed will take the same cable.
My Blog
Car quest part number CA-3002 will work
But it has a black plastic cover instead of the metal.
Awesome! Thx DADS. If nobody knows of a metal shielded one I'll pick that one up.
1952 Chevy 3100
Semper Fi !
Hey y'all, may I jump in and ask for advice @ which speedo cable would work for my '52? Running the stock speedo but a 700R4 tranny.
Thank you in advance!
I just tried to install the Carquest CA-3002 and noticed the connector at the speedo end doesn't have a threaded coupling like the original. Any other options?
1952 Chevy 3100
Semper Fi !
That's ...click... odd
Should look like this ..click.
...click...
So the cable came with just one connector?
did you get this sorted out?
Riding in the Passing Lane
The one with out the threaded connection is for later models. About 70 on back should fit. Measure the length & match it up or a little bit longer. I prefer the metal caseing. Some of the specialty suppliers have it that way. If your caseing is good you can make up the core with a speedo core kit.
1972 Chevy c10 Cheyenne Super
OK. Here's what happened. The Carquest number turned out to be CA-3004. It has the threaded coupling on the speedo end instead of the press on connector. Installed it, works fine.
1952 Chevy 3100
Semper Fi !
The speedo part number I posted ca-3002 had the correct fittings on both ends and is about 64 inches long.
But this purchase was about 4 years ago.
Glad you got the correct part.
