0 members (), 102 guests, and 3 robots.
Topics128,186
Posts1,057,319
Members48,469
#1018593 04/01/2014 1:13 AM
Removed front fenders from donor truck today,'55 1st 3/4 ton . noticed 1 hole in top of both fenders 3/8" about 7" from front of fender, they both was bondo over . Was these made by PO or factory ???? Thanks
" STUCK IN THE '50'S "
Sounds like aftermarket lights to me.
Lots more pictures
Agreed - directional/marker lamps.
Not factory installed - installed by dealer/owner. There were GM accessory front-fender-mounted lamps and many types of after market front-fender-mounted lamps.
Thanks I'll weld the holes up ....
I filled mine in. Had no intention of keeping those farm truck type of lights on the fenders.
I did however run across one of my front fenders with two holes on the side, right over the front wheel opening. One fender has them, the other doesn't. I know they're from different trucks, but I have never seen these holes on the front fenders before. Almost as if someone meant to rivet a bracket there or something.
Anyone else seen these before? Maybe know what they were used for?
Plumber truck. Rack mount to hold pipe in long lengths would have been on the passenger side. Dads truck had them and he hated them moved to under the bumper and he was happy. My job was to lift the pipe as he pushed it under the truck. smile
Steve H
Steve H. Thank you for that information. You're right, these ARE on the passenger side front fender.
Settles that question...now off to weld them shut so I'm that much closer to being ready for a paint booth!
